Davis Driver's Any one used ?
Has any one used the davis drivers > http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=297-570
Specifications: *Power handling: 50 watts RMS/75 watts max *VCdia: 1" *Le: .61 mH *Znom: 8 ohms *Re: 6.16 ohms *Frequency range: 45-4,000 Hz *Fs: 43 Hz *SPL: 92 dB 1W/1m *Vas: 1.06 cu. ft. *Qms: 2.46 *Qes: .61 *Qts: .40 *Xmax: 3 mm *Dimensions: Overall Diameter: 6-5/8" by 7-1/2" Cutout Diameter: 5-3/4" Mounting Depth: 2-3/4".
I'd like to see what people have done. I just bought a pair and going to be building a ported 2 way speaker.
I bought a pair of these.
http://www.madisound.com/cgi-bin/index.cgi?cart_id=6239969.18461&pid=1935
Outside diameter 103.8mm
Cut out 73mm
Depth 24.5mm
25.4mm = 1" = 2.54cm
Nominal Impedance 6 Ohms
Recom. frequency range 2200-25000 Hz
Short term max. power 200 W
Long term max. power 90 W
Sensitivity (1W/1m) 92 dB
Voice Coil Diameter 26 mm
Voice coil height 1.5 mm
Air gap height 2.0 mm
Linear coil travel (p-p) 0.5 mm
Max. coil travel (p-p) - mm
Magnet weight 0.25 Kg
Total weight 0.53 Kg
Voice coil resistance 4.7 Ohms
Voice coil inductance 0.05 mH
Force factor 3.5 N/A
Free air resonance 950 Hz
Moving mass 0.35 g
Suspension compliance - mm/N
Suspension mech. resistance - Ns/m
Effective piston area 8 sq. cm
Davis driver
I know both of them. The Davis is too expensive forwhat it worth, but still a good driver, limited application though. Their high Q (0.4) makes them only suitabe for larger Bass-reflex design. It's not totally dry, but pleasant sound. The tweeter is a Seas, very nice device.
IfI would have to choose, I'd take a Scan-Speak 18W/8546 drivers, which requires small enclosure, has also a Kevlar diaphragm, but it's adream of a speaker.
- dan
Curmudgeon said:
Is the Kevlar coated, (like the ScanSpeaks) or is it bare? If bare, I've seen some uncoated Kevlar cones break up quite harshly.
Any Kevlar diaphragm is coated, because if not it wouldn't be airtight. The Davis speakers are not heavily coated though, just a latex-like layer, and also the Scan-Speaks have a more refined coating. To decrease the peaks try the "Sound Varnish 'D' " coating, which brings excellent results (distributed by Strassacker - see www.lautsprechershop.de/hifi/daemmen_en.htm). Don't use the one without the D suffix (D= damping, for Kevlar, Glassfibre, Alu cones and sometimes carbon cones/ domes), this one is designed for paper and fabric diaphragms.
- dan
