waiting ...
Hello,
I am still waiting ...
I am the only who didn't know this well known factor, sorry.
It is the most important mathematical tool in triode circuit design.
Thus I am sure the experts here are able to tell me the name of it.
Thanks,
Darius
Hello,
Originally #42 posted by SY
I'm sorry, I just don't have an English word for it. I'll look in a couple of texts and see if there actually is one.
Thanks,
Darius
Loftin White ... "Ultrapath" ... Broskie
Hello,
anyone noticed this blog by Broskie? read me
quoted from Radio News Feb.1930: "A condenser, C2, of about 1 microfarad is needed to form a local signal circuit in the output circuit including association of any suitable loud speaker as indicated." link
This is the so called "Ultrapath" and the green line shows this
local output circuit in my fundamental schematics.
http://rl12t15.blogspot.com/2008/03/ecc83-300b-darius-loftin-white.html
Schematic
http://rl12t15.blogspot.com/2007/09/pc86-rl12t15-darius-loftin-white.html
Schematic
I am sure Broskies text will help you understanding the "Ultrapath
aspect" of a true Loftin White design. Thanks to JRB.
Kind regards,
Darius
Hello,
Schematic
Schematic
Kind regards,
Darius
Darius,
In your schematic, where is the 1uF cap from the ground input to the cathode resistor of the input tube as shown on the original schematic? Is it necessary?
Happy new 2009,
Happy new 2009,
Darius exited the forum. A little to loose here for him, maybe. In any case, C2 on his schematic is the 24u cap, and Chb is the 2.2u cap. C2 on his schematic is just shown on the right side of the tube, instead of the left. But if you look closely, you will see that the connection is exactly the same (top of cathode resistor to B+). Yes, it is necessary.
Sheldon
Sheldon
Sheldon said:Darius exited the forum. A little to loose here for him, maybe. In any case, C2 on his schematic is the 24u cap, and Chb is the 2.2u cap. C2 on his schematic is just shown on the right side of the tube, instead of the left. But if you look closely, you will see that the connection is exactly the same (top of cathode resistor to B+). Yes, it is necessary.
Sheldon
C2 and Chb are clear. I do not see the C1 cap at the input and the 6SN7 grid leak resistor goes straight to ground.
here is a clearer picture:
In either case, I'm not sure that I see the benefit. Darius' triode LW version references the signal circuit to the top of the cathode output resistor, to eliminate PS ripple from the output. The original does the same, but uses a pentode input tube.
In version 1, the screen grid already isolates the output tube from the effects of ripple in B1. The CCS on the input tube should isolate it from B2 ripple. The ripple compensation circuit will eliminate ripple from B2 on the screen grid, but it should be easy to get that low current supply quiet anyway.
In version 2, more or less the same things apply, but with one less cap. I'd do that one.
Sheldon
Sheldon
Originally #67 posted by korneluk
Hello korneluc
thanks for your question. I am using an input triode. The 'well known factor' for this triode is > 4 therefore I don't need this cap.
Kind regards,
Darius
Folks,
The Cunningham CX-350 data sheet specifies that "the '50 is not recommended for use in resistance-coupled circuits having a grid resistor". However, in the original LW circuit the grid of the 50 is directly connected to the plate of the 224. See schematic posted above.
Does this arrangement violate the spec?
-- josé k.
-- josé k.
Very true.... but later when the type 50 in ST glass became available, RCA changed this (newer manual)... stating that any conventional type of coupling may be used provided the resistance added to the grid circuit by this device does not exceed 10,000 ohms. That's a pretty low resistance, implying that the 50 can get into a runaway condition.
In any case, you bring up a valid concern. In a traditional self-bias circuit, you could get runaway with a higher grid resistance and things would get ugly... I have a couple 2A3 tubes which do this, hence they may be a bit gassy. As you have a DC coupling from the 224 with a current flow of 1ma (thru the 224), it's unlikely to have the runaway problem as the 1ma of current should be far greater than the grid leakage current of the 50 triode. I'd probably be inclined to increase the driver idle current to be on the safer side which would improve the slew rate for the driver.
Regards, KM
Regards, KM
@ #73 and #74
Please read the radio news articles, thanks.
Re: @ #73 and #74
Hallo Darius,
I have part 3 of the Radio News article series (not in your blog) where it shows the actual part values using a 45 tube. Please email me offline and I'll be glad to send them to you.
Grüße
-- josé k.
jose_korneluk AT bellsouth.net
oldeurope said:Please read the radio news articles, thanks.
Hallo Darius,
Grüße
-- josé k.
@ #76
Thanks José,
I sent you an email.
In my old circuit I had some trouble with drifting bias current for the RL12T15.
The resistor 220KΩ+390KΩ was much too high and little voltage drops made
big changes in bias because of the relatively low cathode resistor 1KΩ.
The Loftin White topology solved this problem and reduced the AC load impedance
for the driver stage. schematic
comes from
Kind regards,
Darius
Thanks José,
comes from
Kind regards,
Darius
Re: @ #76
correction:
The Loftin White topology increased the AC load impedance for the driver stage.
Means less load for the driver stage.
Have a look at #69 The triode works in no load operation (current source). Loftin White makes this possible.
See this one bootstrap
comes from
correction:
oldeurope said:The Loftin White topology solved this problem and reduced the AC load impedance
comes from
It takes some work to get all the operating values set for a true LW amp, as they are all interdependent. However, once set, the operating points are very stable and self correcting.
On question Darius, on the clever bootstrap. How is the output impedance calculated? The feedback from the bootstrap should increase the impedance. From this article: http://www.tubecad.com/articles_2002/SRPP_Deconstructed/page5.html
It suggests that the amount of the output fed back to the input is calculated according to the ratio between the resistor from plate to feedback cap, and the rp of the input tube (in this case, about 225K). So for this example, about 50% of the output is fed back to the input, in phase. I assume that the output impedance of the follower would be increased by approximately double?
Sheldon
Sheldon
- Tubes / Valves
- Darius Loftin White explained
