Daft Hybrid Amp
I don't get it , why do all these dangerous lashups sound so good ? Had this one up for the last few weeks , started with choke loaded IRFP150 , found a bias sweetspot at 1.5A and went from there :) Could probably do with more current but I'd imagine the chokes are running on the ragged edge :hot: Original input valve was a 5687 , then changed to type 26 , now running 15E . Total lashup , using a voltage doubler to get 250V HT and running the 15E at 180V/2.5mA which is far too low , but it sounds good as it is :) The filaments of the input valves draw 20 watts each , the mosfets are running at 15 watts dissipation per device . Filament supply weighs 30kg . Not really chassis happy but never mind , I'm enjoying this thing as it is:clown:
316A
