DAC-END R (ES9018) full assembled board - version 2
Update to my entry Algar_emi
Choice 1: full
1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer + chassis
3. rade95: DAC module + amanero + output stage + transformer + chassis
4. PeterKD: complete DAC (item 6)
5. schallundrauch: complete DAC (item 6)
6. msaywitz: DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
7. jokari69: DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
8. wuming: Assembled DAC, BUT exclude option 2 AND plus assembled Super V/I LL1684
9. boudy: Complete assembled DAC excluding option 2 and including the LL1684 transformer I/V
10. stokessd: Assembled DAC, BUT exclude option 2 AND plus assembled Super V/I Ll1684
11. vmoreau: complete assembled set (DAC Module +Output Stage +amanero +transformers configured for 230VAC operation + chassis)
12. BinarySeeker: Assembled DAC, BUT exclude option 2 AND add assembled Super V/I LL1684
13. eboz: complete DAC (item 6)
14. rowli: Complete DAC (item 6) without output stage + Super V/I LL1684(1,2,3,5,7,8)
15. Apogee: completed DAC (item 6) + 1 pair of the Super V/I converter pcb's
16. Macrotourist (post 396) complete set: item 6
17. Nimes (post 421) complete DAC (item 6)
18. Serge58: assembled set (DAC Module +Output Stage + amanero +2х r-core transformers configured for 220 VAC operation + chassis)
Choice 2: output stage only
1. CAAD: output stage only
2. claudio52: Output stage + 2 transformers R25
3. Erlend Sæterdal: Output stage only
4. rredline: Output stage only
5. danny_66: output stage only
6. gjorgji: output stage only
7. ylaw: output stage only + shield for DAC.
8. BinarySeeker: output stage only
Choice 3: DAC complete without output stage
1. sandor: Complete DAC without output stage
2. Nick F: Complete DAC exclude output stage
3. Mas Penk: DAC module + amanero + 2x transformer + chassis
4. Danielkol: DAC module + chassis + 3*Amanero boards
Choice 4: Customised
1. smokingdog: DAC module + output stage
2. gde3: DAC module + amanero + transformer
3. brgds: DAC + output stage + amanero
4. anjogi: amanero + DAC + output stage + transformer
5. frankwilker: DAC module + Amanero module + output stage
6. NKL: DAC module + Amanero module+output stage+transformer
7. ervstil: DAC module + Amanero + output stage + silver buttons for control board
8. Claudio M: DAC module + amanero + output stage + LL1684 pcb + transformer
9. ceausuc: Amanero
10. xtomm: DAC module + output stage + 2 rcore transformers
11. Corpius: DAC Module + Output stage + chassis + transformer
12. Ardahan: DAC Module
13. johnnyti: amanero
14. axeexa (antony_shih): DAC module + output stage + Chassie + Super V/I (1+2)x2
15. Algar_emi: DAC Module + Output stage + Amanero + chassis[/QUOTE]
With all long thread, it is difficult to parse, here a table of content to help find all the info included:
New Discrete I/V dCS output, block diagram, p.1, PCB layout p.4, schematic p.10
prototype p.8
DAC Structure p.9
Enclosure, black with new display p.10
PCB test production run p.11
Remote guide p.13
DAC PCB layout p12, 3D layout & dCS pcb p.17
DAC PCB 3D Layout LL1684 output and discrete I/V versions p.22
DAC PCB 1st actual picture p.22
Isolator ISO 7640 and reclock with buffer p.24
Discrete I/V PCB details & 3D views p.24
I2S insulator p.27
DAC Kit included p.28
Actual PCB photos p.36
Chassis layout p.28 & 37
DEC PCB on test p.38 & 39
Sabre32 unlock shield p.45
http://www.diyaudio.com/forums/quan...55-dac-end-r-es9018-full-assembled-board.html
Chassis detailled dimensions p.14 & 15
Amanero supplies mods details p.33
Version 1, pcb p.43
Output Stage to Test p.65
DAC shield p.100
Discrete I/V first prototype p.100
And the rest of the Version1 links. There some interesting reading there:
Version 1, pcb p.43
DAC shield, 1st version p.100, production version p.101, installed p.114
AES/EBU and SPDIF missing C35,C36 mods with schematc p.108
Again SPDIF schematic discussion p.109
SPDIF circuit simulation p.110
Output DC offset change instructions p.118
Remote volume setting guide p.123
Shunt Reg current adjust p.138 (10ohm,std = 60mA, 15 ohm = 40mA)
To see firmware version at startup, press 'Menu' p.139
Firmware upgrade, howto p.147
firmware ver. 51a, p.140
firmware ver. 52a and mod, p.142
firmware ver. 57a, p.158
firmware ver. 58a, p.203
firmware ver. 58a standby, p.206
Regs noise explain p.144
Shunt Regs small upgrade p.159 & 163
jumper to remove to use computer supply for the usb p.166
Amanero, To use 3.3V from dac, remove this IC p.169
JRiver DSD instructions p.179
coax SPDIF 192Khz, found bad part p.194
Fix SPDIF 96K 192KHz locking issue p.195 & 200
Fix AES-EBU 96K 192KHz locking issue p.201
List Paid for Dac-End R - Ver 2
Hi, below is a list of your paid for DAC-END R (ES9018) full assembled board - version 2, updated 17/02/2014
List Paid
1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6): 500usd (Date: 3/1/2014)
2. Corpius: DAC Module + Output stage + chassis + transformer: 400usd (Date: 3/1/2014)
3. msaywitz: DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6): 450usd (4/1/2014)
4. Nick F: Complete DAC exclude output stage: 400usd (Date: 5/1/2014)
5. papapew: DAC module + amanero + output stage + transformer + chassis: 385usd (Date: 5/1/2014)
6. claudio52: Output stage + 2 tranformers R25: 90usd (Date: 6/1/2014)
7. rredline: Output stage only: 50usd (Date: 7/1/2014)
8. brgds: DAC + output stage + amanero: 305usd (Date: 7/1/2014)
9. Ardahan: DAC Module: 225usd (Date: 7/1/2014)
10. anjogi: amanero + DAC + output stage + transformer : 345usd (Date: 8/1/2014)
11. vmoreau=complete assembled set (DAC Module +Output Stage +amanero +transformers configured for 230VAC operation + chassis): 450usd (Date: 8/1/2014)
12. gde3: DAC module + amanero + transformer, total: 550usd; 255 usd (Date: 9/1/2014)
13. danny_66: output stage only, total: 150usd; 75usd (Date: 9/1/2014)
14. boudy: Complete assembled dac, total: 900usd; 450usd (Date: 9/1/2014)
15. Claudio M: DAC module + amanero + output stage + LL1684 pcb + transformer; 372usd (Date: 9/1/2014)
16. Mas Penk: DAC module + amanero + transformer + chassis + Super IV LL1684;
(Paid 1: 360usd , Date: 9/1/204; Paid 2: 300usd, 12/01/2014)
17. xtomm: DAC module + output stage; 340usd (Date: 10/1/2014)
18. Dudek1 (Complete Set: Item 6); 450usd (Date: 10/1/2014)
19. ervstil: DAC module + Amanero + output stage + silver buttons for control board; 330usd (Date 11/1/2014)
20. sandor: Complete DAC without output stage (Paid 375usd, date 12/11/2014)
21. Danielkol: DAC module + chassis + 3 Amonero (Paid 375usd, date 12/11/2014)
22. ceausuc: Amanero (Paid 30usd, date 12/11/2014)
23. gjorgji: output stage only + 2 tranformer (Paid 115usd, date 12/01/2014)
24. Jonnnyti: amanero (Paid 30 usd, date 13/01/2014)
25. frankwilker: DAC module + Amanero module + output stage (Paid 400 usd, date 15/01/2014)
26. Hans Nielsen: (paid 1: 450usd, date 17/01/2014)
27. Michael Woods (paid 1: 450usd, date 17/01/2014)
28. Apogee: completed DAC (item 6) + 1 pair of the Super V/I converter pcb's (paid: 462.5usd, date 21/01/2014)
29. rowli: Complete DAC (item 6) without output stage + Super V/I LL1684(1,2,3,5,7,8), (paid: 542.95usd, date 21/01/2014)
30. CAAD: output stage only (paid: 75usd, date 22/01/2014)
31. PeterKD: complete DAC (item 6) (paid: 450usd, date 22/01/2014)
32. ylaw: output stage only + shield for DAC (paid: 160usd, date 04/02/2014)
33. Nimes complete DAC (item 6), (paid: 160usd, date 12/02/2014)
Transfo PCB dimensions
Hi Quanghao. Do you have the transfo PCB dimensions as shown on this 3D rendering of your DAC. I'll make a pcb and I want to make sure it will fit into the chassis. Or even better if you have the Gerber of your design, I can use it.
Thanks. SB
The chassis
after two weeks of work from 8am to 22 pm. I came back, went over 2000 km, I had chassis model is complete, all the silver aluminum. Please see results. I'm happy!
Thank you very much, more!
