Information: HQ DAC reference ES9018S
HQ reference DAC ES9018S - USB PCM / DSD DAC
Digital-to-analogue converter. DAC- ESS Sabre32 9018 chip. Resolution, 32 bits.
Technical Specifications :
● SNR: >120dB.
● Dynamic Range: 115dB.
● THD+N: <0.0005% at 1KHZ
The design philosophy: Combination of Art and Audio
A. HQ reference DAC ES9018S Module have these features:
1. Input: - 4 inputs:
1. USB, without USB Amanero on board.
2. Spdif coax with DELUXE RCA on board.
3. AES/EBU with NEUTRIK XLR FEMALE NC3FAAH on board.
4. Optical Toslink with TORX177 one board.
- Amanero module integrated to have USB input
- Support 44,88,96,192,352,384KHz PCM and DSD to play SACD ISO
- Full ground isolation from USB module
- Isolator I2S with ISO7640
2. Outputs: Stereo (2 Channels) or mono with a voltage output or current output
- The ES9018 have 8 channel DAC that can be configure in parallel to get a stereo output and to increase the performances.
- Using the current mode should be necessary to use an external current to voltage stage (I/V).
- On board a passive I/V created with a set of 1 x 10ohm 1% resistor, using this value the final DAC output will be 1.6Vrms with op-amp and 1.4Vrms with vacuum tube stage.
- The DAC can work with a voltage output or current output with use jum.
- Optional passive I/V
3. Clock: This is a critical component, the sound performances can be compromised with a cheap oscillator so we are using the CCHD-575 Ultra-Low Phase Noise Crystal Oscillator, 3.3V HCMOS.
· The frequency 100MHz as been choiced to support any PCM and any DSD sampling frequency.
· On board reference 100MHz Crystek oscillator with a jitter of 0.5psec
· Ultra fast oscillator buffer
4. Remote control : Board LCD with RMB-CM11111 Remote Control Volume.
- 4 row x 20 characters LCD
- PIC Microcontroller to remap DAC and share I2S connection with DSD signals
- Controller compatible with any 5V LCD and VFD
- Simple firmware upgrade
- Large dB volume display
- Remote volume control
- Remote mute control
- Remote input control
- Digital filter control
5. POWER SUPPLY
- 2 x Top performance linear pre-regulator LT1963
- 2 x Separated fast shunt for any digital section
- 5 x Separated fast shunt for any analog channel
6. PCB-DAC
- Material thickness: 1.6mm
- Copper thickness: 35µ (1oz)
- Special surface treatment: gold-plated
7. Components:
- The capacitors: Matura, Wima, Os-con, Panasonic
- The Resistors: All use MELF Resistors Vishay
- The main components are bought from the site: Mouser Electronics - Electronic Components Distributor
8. HQ reference DAC ES9018S Module
- Assembled and Tested
9. Warranty:
- 1 year warranty, if fault ES9018 chip, support and technical issues updating the firmware upgrade
B. DCD V/I Converted - Direct Coupled Differential with Class A output stage:
1. Use and Inputs: Use with DAC voltage output :
- ES9018, CS4398, FN1242, WM8741, AK4397... WM8741, AK4397...
2. Output:
- Full balance L+R
Balance output on XLR left and right with NEUTRIK XLR MALE NC3MAAH-1 on board
- Singed output on RCA DELUXE RCA on board
- Headphone: play with headphone 70 Ohm.
3. Information:
- no feedback
- very low distortion because it work as current amplifier
- Full class A operation on any load
- Dual Single Ended mosfet buffer
- zero dc offset using dc servo loop
- variable voltage gain only changing a single resistor (I/V)
- 3 voltage amplification setting with jumps
- high output current to drive any low impedance headphone in pure class A
- high output voltage to drive any high impedance headphone
- very low output impedance to drive any cable
- both un-balanced and balanced output
- differential configuration to reduce common mode DAC errors
- output relay for the startup-up phase
- discrete high current shunt regulators
4. Sound Characteristics:
-Material thickness: 1.6mm
-Copper thickness: 35µ (1oz)
-Special surface treatment: gold-plated
6. Components:
7. DCD V/I Converted Module
It is these people who are important to you make a successful design.
Andrea looks forward to Hq-DAC will satisfy the ears of music you!
● SNR: >120dB.
5. POWER SUPPLY
6. PCB-DAC
7. Components:
9. Warranty:
2. Output:
- Full balance L+R
3. Information:
- no feedback
- The sound very natural and detailed balance
6. Components:
The price all module –HQ DAC
1. DAC ES9018 module have these features:
· 1 x Main DAC
· 1 x main LCD
· 1 x Control Volume
· 1 x 7pinwireconnectedtheLCD toDAC
DAC module assembled and tested with all components
The price : 450 $
2. DCD V/I Converted - Direct Coupled Differential with Class A output stage:
· 2 x Main DCD ( L+R):
· 2X RCA one board
· 2 x NEUTRIK XLR on board
· DCD module assembled and tested with all components
The price : 100 $
3. Chassis : Aluminium Silver Chassis includes:
· 5 x function button
· 1 x power button
· 4 x Chassis Feet Pad
· 1 x front chassis : Aluminium Silver
· 1 x back chassis
· 1 x bottom chassis
· 1x face on chassis
· 2 x side chassis
· 1 x Plastic – mica
· 25 x Screw 3 x 10mm
1 x module Power swich includes:
· 1 x power swich
· 1x power switch knob
· 1 PCB power swich
· 1 x power switch-KDC-A11
· 1 x RF-1002 voltageselector…
The price : 120 $
4. R-Core transformer: This DAC need 2 x R-Core transformer:
· Primary : 0-115V, 0- 115V
· Secondary: 0-6.5V/1A, 18v-V-0-18V/1A
The price : 40 $/ a transformer
5. Amanero module:
The price : 60 $
6. Assembled DAC, this include option 1,2,3,4,5 (it is possible exclude option 2)
The price : 900 $
Thanks for your interest!
quanghao
· 1 x Main DAC
· 1 x main LCD
The price : 450 $
· 2X RCA one board
The price : 100 $
· 1 x power button
· 1 x back chassis
· 2 x side chassis
· 1 x power swich
· 1 PCB power swich
The price : 120 $
5. Amanero module:
The price : 60 $
The price : 900 $
quanghao
Good optimization, these will give extra confidence in quality!
I believe Matura is Murata...
I hope the LMV7219 are not ordered from Mouser...
Would like see a picture of the new Dual Single Ended mosfet buffer DCS I/V.
You may consider open a new standalone thread just for the DCS I/V as many people do not know this can be used on other DACs.
yes Murata, and Lmv7219 order from mouse!
thanks
thanks
But the LMV7219 from Mouser are faulty/fake, can not support 96/192KHz.
LMV7219 from RS Components are real/OK, can support 96/192KHz.
See here
See here
yes, i see last time i got it was bad, im very sorry!
thanks
Production Planning DAC 32 V2
Hq - DAC - This is one of the designs of Andrea and my heart , you can see through the research process layout is as follows :
I have done up to 5 times the actual PCB layout and editing a lot more time to be completed and the experiences and advice of CAAD has given me a lot of changes to the layout DAC achieve optimal quality .
I am very happy and feel very grateful CAAD shared an important experience in Audio Design ! Besides he has to help me measure DAC check and test run part DCD - V / I for Dac .
Thank you very much ! I would put production plans DAC32 V2 .
1 . Get money set production DAC32 :
03/01/2014 to 12/01/2014.
2 . Buy the electronic component parts :
13/01/2014 to 22/01/2014.
3 . Test preparation and installation of welding on automatic welding machine :
23/01/1014 to 25/01/2014.
4 . Vietnamese traditional Tet holiday:
26/01/2014 to 15/02/2014.
5 . Production of the DAC
16/02/2014 to 26/02/2014.
6 . Check test run DAC
27/02/2014 to 27/03/2014.
7 . Packaging and test preparation to send DAC members
from 27/03/2014 to 02/04/2014.
8 . Send to DAC members :
02/04/2014 to 10/04/2014.
9 . Summary.
Thank you for your attention to this DAC design !
The advance payment you please give me 50 % of the amount you have chosen , I have the money to buy the ingredients for production and confirm your subscription DAC .
Payment period begins on : 03/01/2014 and end on 12/01/2014 .
Everyone please send payment to my paypal account : quanghao168@yahoo.com.vn
Thank you !
Quanghao
9 . Summary.
Thank you !
Quanghao
Guanghao or Andrea,
Could you please let me know what the exact distances are between the button?
this for you!
thanks
Hi Quanghao,
do you think this transformer can work with just the dac module?
I have a couple of those laying around and some recycling is always good, thanks in advance for the answer
Hi Quanghao,
yes.
No good !
Please use this: it is good for DAC : TE70050-ND
Invalid Request
And For DCD V/I
it is : TE70084-ND
: Invalid Request
thanks
Hello Quanghao , hello All
I have finaly change my choice for a full set (removed myself from Choice 4 list, and added in 12th position in Choice 1 list). I hope this is not a problem fot you at this date.
Let me know how to send payment ? (paypal I guess, but I need your mail adress)
Many thanks.
Choice 1: full
1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer + chassis
3. villanueva: DAC module + amanero + output stage + transformer (item6)
4. rade95: DAC module + amanero + output stage + transformer + chassis
5. PeterKD: complete DAC (item 6)
6. schallundrauch: complete DAC (item 6)
7. msaywitz: DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
8. jokari69: DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
9. wuming: Assembled DAC, BUT exclude option 2 AND plus assembled Super V/I Ll1684
10. boudy: Complete assembled dac
11. stokessd: Assembled DAC, BUT exclude option 2 AND plus assembled Super V/I Ll1684
12. vmoreau=complete assembled set (DAC Module +Output Stage +amanero +transformers configured for 230VAC operation + chassis)
Choice 2: output stage only
1. CAAD: output stage only
2. Blackberry: output stage only
3. claudio52: Output stage only
4. Erlend Sæterdal: Output stage only
5. rredline: Output stage only
6. danny_66: output stage only
7. gjorgji: output stage only
8. ylaw: output stage only + shield for DAC.
Choice 3: DAC complete without output stage
1. sandor: Complete DAC without output stage
2. Stenachio: Complete DAC without output stage
3. Nick F: Complete DAC exclude output stage
4. Mas Penk: DAC module + amanero + transformer + chassis
5. Danielkol: DAC module + chassis
Choice 4: Customised
1. smokingdog: DAC module + output stage
2. gde3: DAC module + amanero + transformer
3. brgds: DAC + output stage + amanero
4. anjogi: amanero + DAC + output stage + transformer
5. frankwilker: DAC module + Amanero module + output stage
6. NKL: DAC module + Amanero module+output stage+transformer
7. ervstil: DAC module + Amanero + output stage + silver buttons for control board
8. rowli: DAC module + amanero + transformer
9. Claudio M: DAC module + amanero + output stage + LL1684 pcb + transformer
10. ceausuc: Amanero
11. xtomm: DAC module + output stage
12. Corpius: DAC Module + Output stage + chassis + transformer
13. Ardahan: DAC Module
Many thanks.
Choice 1: full
Many thanks.
no problem!
yes may paypal!
thanks
Hi Quanghao,
I have subscribed this group buy for a complete DAC without the solid state output stage. And I have also subscribed the other group buy for the output stage with the LL1684 transformers + pcb + components.
I am currently listed in the group "Choice 3" of this group buy.
Should I move to the group "Choice 4: Customised" ?
Hi Quanghao,
Hi!
no problem, if you like!
And PCB LL1684 i will post some day later!
thanks
If I understand well, for the time being I have to pay 800 USD (900 USD for the assembled DAC - 100 USD of the output stage).
And you will inform us later about the price of the LL1684 pcb + transformers + components.
Right ?
the LL1684 pcb + transformers + components. you can sent to me later!
thanks
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board - version 2
