to anyone who's looking for further mod, maybe you can replace the hex inverter with the better one: Buy Inverter Schmitt Trigger IC,Logic,VHC Family,Inverter Hex CMOS,SOIC14 Fairchild Semiconductor 74VHC04M online from RS for next day delivery.
someone recommended me this in the dacmagic mod thread, he said the improvement is noticeable. it's a cheap upgrade, should be worth the shot
i haven't tried this myself since my components hasn't arrived yet
The schematic I've seen shows the Hex inverter driving three LEDs, providing a static signal driving unused inputs, and generating the reset pulse.
Please explain how changing the hex inverter made a "noticable improvement".
no idea. i'm just passing away information
maybe you should give them a try and see for yourself. since this mod costs almost nothing
i quoted the conversation between me and this guy, who recommended the inverter mod
is the ak4396 chip getting the clock signal from 74VHC04M as well in this module?
Regarding 74vhc14, is the distributor of the clock signal DacMagic. Before installing the Flea 5volts put another clock in and burned 74. The code "V" 74 "V" hc indicates an integrated low noise. Currently installed the 74HC14 is not low noise but it works.
The kit is finished.
It works perfectly! Voltages are all in +/- 0.02V tolerance. I used two separate transformers.
Compared to the internal DAC of my Yamaha DSP-A1 (12 years old), and the new kit, the difference is noticeable. The original Yamaha DAC is very "harsh" sounding, the new kit with the NE5532 as an op-amp is much better. Much "warmer".
Maybe I should change it to and OPA627 or OPA2132?
Or just leave it.
Or just leave it.
idjoel2000 very good. IF the clock is buffered by the 74HC/VHC inverter, then there is the possibility of improving the SQ as jitter can be noise related.
In this case I agree it might be worth changing.
The schematic I saw did not buffer the clock with it, so it would make no difference in that version.
Or just leave it.
try the 627, many people like them. but it comes in an expense as well, the price is quite steep
ahha.. it would not be worth the effort then
Or just leave it.
OPA827, much cheaper than OPA627 and better sounding, IMHO.
No, what TheGimp wrote is that in MINI2496 changing that component has no effect on audio...
On the PCB there's no clock at all to buffer...
so you think changing the inverter would yield some result? i thought the mini2496 schematic is the same as in this one?
I think I wrote clearly...
NO
NO
sorry, i misread your previous comment!
No problem
Hey, the CATO is on sale...
Welborne Labs CATO Vacuum Tube Linestage
It looks like a good output option for the ak4396 dac. (but I guess ak4396 doesn't need a i/v converter).
OPA627: 4$ on e-bay, including soldered on an adapter for SIL insertion.
OPA827 +/- 8$ but you need to solder the SMD yourself to an adapter
For comparison:
Farnell:
OPA627: € 32,50
OPA827: € 15,00 (also, only in SMD possible)
RS components:
OPA627: € 28,69 (in SMD)
OPA827: € 7,91 (in SMD)
Mouser:
OPE627: € 14,81 (SIL)
OPA827: € 8,17 (in SMD)
Interesting price range.
Benefit of RS, Farnell, Mouser etc.... Order today, receive tomorrow. With E-bay through China, it takes 3-4 weeks. But heck... 4$ for a OPA627.... or € 14 through Mouser (with € 20 shipping)..... Choice is easy.
But... I see that both op-amps are single only. The NE5532 is a dual. So I need a conversion socket?
For comparison:
Farnell:
OPA627: € 32,50
RS components:
Mouser:
I'm not advertising in any way but this is where I bought my OPA827 + adapter board.
OPA827AID x2 + Adaptor Single to Dual | eBay
Huge difference with the OPA627. About $8,00 incl shipping.
2pcs BB OPA627 OPA627AU on SOIC DIP adapter gold plated PCB adn Pin | eBay
- Digital Line Level
- DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
