Re: 2Sc2705 is NPN as 2SD666AC.... so, they may be equivalent
So,
2SC2705 is ~ 2SD666AC
and
2SA1145 is ~ 2SB646
Thanks Carlos!
destroyer X said:And the others may be PNP and equivalents too.
Good luck
regards,
Carlos
So,
and
2SA1145 is ~ 2SB646
Thanks Carlos!
hey nina,
Nikko Electronics has both 646/666
http://www.nikko-electronics.net/se...AC&PHPSESSID=0f95a75be3db011084b3f24e9f6d5edb
Magura said:Hey what is this, Carlos is speaking a language that I actually understand.....and I think it's even right on topic...now that's great news Magura
arh ha ! Magura, if you admit to not usually understanding Carlos's posts....then how do you know he posts off topic???....answer me that.
Well, usually his posts contains a photo of a girl or the like.
Magura
Magura said:Well, usually his posts contains a photo of a girl or the like.
Yes, but that girl is the amp construction supervisor or assembly assistant, and the pictures of food are the energy source required to build amps at the Carlos's hectic pace.
I rest my case
The construction supervisor is quite pretty as I remember
Magura
- ? D666AC, B646AC -vs-C2705 ,A1145 - which one substitute which one?
