@ebijma:
I know some sources for Tangband in Germany,
e. g. www.spectrumaudio.de
but I dont know how the situation is in The Netherlands. I think that the chances are not bad, as these babies are quite popular these days.
Have fun, nice greetings, Berndt
There is nothing quite like the thrill of getting something for nothing!
Somebody gave me a pair of Pioneer 4 inch drivers and I had them lying around for a few months before connecting them to an amp and hearing that they sounded quite reasonable.
I had seen the Cyburgs design and adapted that by increasing the cabinet width by 25mm. I managed to find somebody throwing out some chipboard and spent a couple of days in my workshop. I already had glue, fibreglass insulating wool and wire so I didn't spend a penny on the whole project.
Last evening I connected them up and was an hour late for supper! They are not the best speakers that I have ever heard and my other speakers are better in several areas. But what they do, they do very well. Great imaging, a huge soundstage (deep and wide) and the speakers themselves are acoustically invisible.
I played some acoustic music first which was very good. With solo vocals, I get close to that 'being there' sensation. But I was surprised at how well they handle rock and orchestral music as well.
For the cost, effort, and time, these speakers have me smiling from ear to ear so a BIG thank you to Cyburgs for sharing his design.
PS - I was going to sling a quick coat of black paint over them but I think that they deserve something a bit better!
Nuuk said:Somebody gave me a pair of Pioneer 4 inch drivers and I had them lying around for a few months before connecting them to an amp and hearing that they sounded quite reasonable.
Another set of official Frugal-phile(tm) speakers
Got close up pictures of the drivers? (including a snap of the back)
Some of these Pioneers were quite good, and most respond to a bit of tweaking.
dave
You mean you want me to stop listening and take a driver out Dave! OK, I'll get one out a little later and take a couple of pictures.
Nuuk said:You mean you want me to stop listening and take a driver out Dave!
Yes... it will probably be worthwhile -- even if i can only provide some useless trivia.
Mark down any numbers & markings too.
dave
Originally posted by Tweakmeister D
4" car speakers... not quite what i was expecting. Do get some ductseal on the basket & fill out the magnet/basket junction so that it is smooth.
Puzzlecoat for sure. those shiny whizzers are kind of interesting, some PK on that wouldn't hurt -- and try the 98 cent tweak.
dave
dave
Nuuk said:
PK?
98 cent tweak?
PK = puzzlecoat, or you could try a mix of turpentine and damar varnish.
98 cent tweak, I think, is something to do with adjusting the whizzer cone with a piece of foam or rubber(?)
Nuuk said:
http://www.t-linespeakers.org/design/tweeks.html
watered down white PVA wood glue is close enuff... dammar i find best on paper whizzers, but it is a widely used treatment. It would probably have little effect on the material of your whizzers.
98 cent tweak?
i no longer have a link to Marc Wauters original treatise.... but it is now used to name any tweak that creates a support for the edge of the whizzer and some damping for the cavity it forms with the cone. My prefered implementation is a thin piece (8-10mm) of very low density foam cut into a strip just wide enuff into friction fit around the whizzer with one cut edge against the edge of the whizzer and the other edge resting on the cone. You want to get away with as little as possible or you can kill the dynamics. (attached is a drawing i did just the other day to illustrate the 98 cent tweak)
You can just make it out in this pic (you can see one end not quite placed right -- i ended up cutting a fresh strip (pink to boot) -- these speakers are probably close relatives of yours, and yours could be put in the same class -- in UK you'd call it a 1 quid speaker.
http://www.t-linespeakers.org/FALL/2buck.html
These really got me going on the path of "a pretty musical speaker can be made for almost nothing" path.
dave
Nuuk said:One coat of diluted PVA glue already applied.
The cone gets a nice shiny finish with the 2nd coat. Don't forget the dustseal (bluetac, even plasticine) on the basket as it is probablythe single most effective mod.
dave
- Full Range
- Cyburgs-Needle for Tangband W3-871S
