I used WD40 for tapping holes in heat sinks, but the smell would stick around for days and my wife would complain when I brought the sinks inside the house. It didn't matter what I did to clean the WD40 off the sinks and my hands, the smell was there, or worse the smell of chemical cleaning products. So I switched to Singer sewing machine oil which has little if no smell at all. I don't know about its properties but it seems to work just as well as WD40, the bottle has a nice long nozzle, and I'm allowed to do wiring in front of the TV again.
AJ
AJ
I use Relton A-9. That stuff's amazing.
~Tom
~Tom
I used to use used engine oil until I was told it can cause cancer !
WD40 is almost as bad, and shouldn't be used indoors at all.
A-9 is awesome for tapping aluminum.
jeff
These are fluids that break down the molecular structure
No, they don't. They're high pressure lubricants, not chemically active.
Inox MX3 is pretty good; unlike WD40 it has a pleasant smell. IMO a better product. Unfortunately probably limited to Australia.
Inox Supreme Lubricants - Inox Lubricants
In my shop we work mostly with aluminum. A9 is a great product.
Lately though,I've been using Walter Alucut. Comes in a grease-gun style tube,
and is about the consistency of wax. We just rub the end of the tube on our bandsaw blades,drill-bits and taps. Marvelous stuff! Obviously not intended for high production machining,which uses flood cooling anyway,but is great for short runs or one-offs.Easy clean up too.
- Design & Build
- Construction Tips
- Cutting Fluid - What do you use?
