CS4396 192/24 DAC for sale *New*
I'm selling my upsampled DAC Kit because I'vo got an Universal Player with SACD playback, thus I couldn't use my DAC anymore.
The device is less than three month old (I'll hand over the invoice), so it's brand new.
The standard Op Amps at the output (I/V and filter) have been replaced by the much better AD8620, the whole think sounds much better. It is of an extreme transparency and staging, warm but not bass-heavy.
I give a Van Den Hul carbonfibre cable with ("The First") which is the statement as a digital cable from the dutch manufacturer.
It has one S/PDIF input (RCA only), a pair of unbalanced RCA and a pair of balanced XLR outputs.
It comes with a 230 volts transformer, a fuseholder and a IEC socket, just plug in everything and let it sing. NO housing
They are two LEDs: one Red for "error" (no signal), and one green "signal" when it detects the digital signal. Output relais mute the analogue signal when ni digital signal is on, but they are not in the signal path but they shorten the output. The whole analogue stage is DC coupled (no capacitor).
Power supply: heavy 100 VA tranny, ultra fast BWY type diodes, Panasonic FC caps for filtering.
Chipset: DAC=CS4396, receiver=CS8414, upsampler=AD1896, OpAMps=AD8620 (4x), output buffers=BUF634.
Output impedance 50 ohms, 3 volts pp on XLR (at 0dB).
Reads everything from 16 to 24 bits, and 32 to 96kHz.
Height 25mm (1"), Circuit is 100mm x 235mm (3.94" x 9.25").
The whole think worth more than 700€, I let it go for 580€ incl. free delivery in Europe .
For more Info: http://www.hoer-wege.de/dacup4396.htm
Picture is taken from the Hörwege Website, my camera is dead.
