crossfire vr4000
Both 70v+ 70v+ pins are directly connected across the board. The cathode goes through those smd transistors and goes. Out through another pin to the gate resistor. Each pair of diodes goes to one group output transistors. I will confirm when I get home
I have an amp with a similar board. ZD10A and ZD12A are 1N4737s. ZD9 and ZD11 are 1N4740s. The anodes are directly connected for each pair.
The connections to the main board are color coded to the legs of the diodes in the second photo.
