I have been experimenting with R value in CRC filter in my tube preamp. What I discovered that lower R values sound better to me than higher, although lower R has higher ripple.
Finally I settled on 220uF - 20 Ohm - 470uF. This filter hums a little, but I must put my ear right next to the speaker to hear it, so it is very quiet anyway.
With lower R in CRC the soundstage is much bigger, sound seems to be faster, better bass, better details, instruments are more separate from their self. Why is that? I thought that better ripple rejection the better sound?
what is the R of the transformer and wiring feeding the CRC?
You actually have an RCRC filter.
If you try adding a little extra R before the first C you may hear something else.
Even better, may be to replace part of the R with an air cored inductor (L+R). Adjust the fixed R values to give the desired (same) B+.
Do ensure that B+ is the same in all the implementations when making your sound quality assessments.
