Counterpoint I/V
Joined 2009
Thanks for answer, I bought 2nd hand your Counterpoint I/V & I have a DAC outputs only SE, the question is answered: if only connect SE input & only connect SE output don't need the Ballsie/Filter but if connect my BII DAC balanced to balanced Counterpoint inputs will need the Ballsie/Filter to connect a SE ouput, right?
