http://m307.photobucket.com/albumview/albums/AudioVoice/09.jpg.html
i have Praxis from Liberty Instruments , but in this moment a friend of my is utilizing the Praxis
Then you can measure T/S specs.
GM
I have a pair of twinaxiom 10's that I can measure tomorrow. They're basically the same but different vintage and they have a small whizzer. It should be close. I wouldn't think that it would change much on the box side. The whizzer is about 3/4" long (or deep) and of relatively small diameter.
Here's two Goodmans twinaxiom 10's
unit 1
Buffer[1] Vas Ver 7.01
Completed: Thu Apr 25 17:57:27 2013
Drive level 100.000% [3.615 mA]
Sine,LoZP(LV/LA)->Vas,21 pts
Re = 13.7772 ohms
Fs = 51.7573 Hz
Zmax = 54.5619 ohms
Qes = 1.9372
Qms = 5.7348
Qts = 1.4481
Le = 0.5175 mH (at 1 kHz)
Diam = 222.2500 mm ( 8.7500 in )
Sd = 38794.7895 mm^2( 60.1320 in^2)
Vas = 126.3630 L ( 4.4625 ft^3)
BL = 6.0829 N/A
Mms = 15.9989 g
Cms = 591.0287 uM/N
Kms = 1691.9651 N/M
Rms = 0.9072 R mechanical
Efficiency = 0.8498 %
Sensitivity= 91.3111 dB @1W/1m
Sensitivity= 88.9504 dB @2.83Vrms/1m
Krm = 52.299E-06 ohms Freq dependent resistance
Erm = 1.075E+00 Rem=Krm*(2*pi*f)^Erm
Kxm = 6.182E-03 Henries Freq dependent reactance
Exm = 721.330E-03 Xem=Kxm*(2*pi*f)^Exm
Ftest = 34.035 Hz
Ftest/Fms = 0.6576
Test Mass used = 21.0000 g (Equal to 4.2 nickels)
Test Mass (Ft=Fms*0.90) = 3.753 g (Add -17.247g for Ft=46.582)
Test Mass (Ft=Fms*0.75) = 12.444 g (Add -8.556g for Ft=38.818)
unit 2
Completed: Thu Apr 25 18:23:33 2013
Drive level 100.000% [3.616 mA]
Sine,LoZP(LV/LA)->Vas,22 pts
Re = 13.9780 ohms
Fs = 55.2288 Hz
Zmax = 55.8164 ohms
Qes = 1.9612
Qms = 5.8701
Qts = 1.4700
Le = 0.5414 mH (at 1 kHz)
Vas = 124.2467 L ( 4.3877 ft^3)
BL = 5.9450 N/A
Mms = 14.2901 g
Cms = 581.1303 uM/N
Kms = 1720.7844 N/M
Rms = 0.8448 R mechanical
Efficiency = 1.0028 %
Sensitivity= 92.0302 dB @1W/1m
Sensitivity= 89.6066 dB @2.83Vrms/1m
Krm = 15.213E-06 ohms Freq dependent resistance
Erm = 1.183E+00 Rem=Krm*(2*pi*f)^Erm
Kxm = 6.772E-03 Henries Freq dependent reactance
Exm = 715.802E-03 Xem=Kxm*(2*pi*f)^Exm
Ftest = 35.144 Hz
Ftest/Fms = 0.6363
Test Mass (Ft=Fms*0.90) = 3.352 g (Add -17.648g for Ft=49.706)
Test Mass (Ft=Fms*0.75) = 11.115 g (Add -9.885g for Ft=41.422)
- Full Range
- Could i build a backload horn whith Axiom10
