Hi scottmoose,
I am trying to find the TSP for a week now and I can not even find the 8A-40 among all corals mentioned on the Web except at diyparadise. Yeo told me to use the data of the Flat 6 and I have only been successful in finding the TSP for the flat 6II.
Coral Flat 6 II :
Re=7,5 Ohm
30Watt
SPL=92dB
Fres=67Hz
Qms=6,9
Qes0,54
Qts=0,50
Vas=37,6 Liter
I think I will need to find someone who can measure the tsp of the 8A-40 to be accurate. I was hoping someone had already done just that.
Friendly regards
Leon
Coral Flat 6 II :
Re=7,5 Ohm
30Watt
SPL=92dB
Fres=67Hz
Qms=6,9
Qes0,54
Qts=0,50
Vas=37,6 Liter
Friendly regards
Leon
Hey,
two options to measure your drivers... if you have a PC.
99$
www.partsexpress.com/pe/showdetl.cfm?&Partnumber=390-804
or for more money, but more complete, the woofer tester 2
www.woofertester.com/products.htm
cheers
/Paba
99$
cheers
/Paba
Hi Alex,
Sorry for the late reply, I have not found or measured the T/S parameters yet. seems to be less simple as it sounds. I am planning on building a cabinet as proposed by coral for the flat 6beta. According to a few people that should come close. I can not find a cabinet proposal for the 8a-40. Coral does not even mention these chassis.
Bonjour Olivier,
Helas, I am located in the "Gard" and going up to paris to have some chassis measured will have to wait until the occasion arises. I will try to find an equivalent store in nimes, montpellier or avignon although I doubt there is any.
Friendly regards
Leon
Bonjour Olivier,
Friendly regards
Leon
- Full Range
- Coral 8A-40
