I have used adum4160, and heard the improvement so I know AD's isolators do the job.
have you used adum4160 on the CM6631 interface?
I read somewhere that used on some other interfaces, this adum chip made the USB-I2S board unrecognisable by the windows drivers and after taking it out, everything switched back to normal
Hi ,
Merry Christmas!
Couldn't wait to heard your result.
Enjoy the holiday.
And to you !
I had a few moments before Boxing day kicks off to do this - added some 100R smd resistors to the I2S lines. It's a hack, so it looks ugly but the connections are 100%. I can add the adum3440 after the resistors.
To do a good job you should mount the clock on the clean side, after the isolator (near the DAC) and send it back to the USB-I2S chip through (another) isolator. I2S lines should be reclocked after the isolator, too.
Of course you need two separated power supplies and the ground on the two sides must be isolated, too.
Frankensolder
On the third attempt, finally, I got reliable strong solder joints. What a dog's dinner. Those smd resistors did not want to co-operate, and I went through 8 of them, but I was determined to use them for the better performance, and finally, it was done and with 100% good connections. The cable is cat6 single core. the grey putty makes sure the joins don't get stressed. I plan to use a filter+3.3V reg for the input side but for initial tests, power is direct from the usb. Unfortunately, I've run out of time so it'll have to wait until the new year to test.
Unix - I have realised you mean desoldering the clocks on the USB side and thus allowing them to be isolated. But there are three xo's, and the usb pcb locates them very close to the CM6631, so I'm certain that relocating them for cleaner power would result in longer lines and more, not less, jitter. So instead I have used a cap multiplier to clean up the usb power to this board, along with an ultra low esr Nichicon PL cap, described in post 46
Your hack gives a new meaning to "isolator"
The adum3440 arrived today. I don't have a wide body adapter pcb, so I cut a regular sop16 in half, soldered on the adum, and then used epoxy putty to make a very strong bridge. I'll try fitting it after the holidays, to see if it makes a difference.
Merry Christmas !
Hi all,
Merry Christmas (late) and happy New Year!
I have one of diyinhk usb to I2s converters but have not been able to make it sing,In foobar it says it's loaded at least down in the left bottom corner and it says the cm audio device is found,drivers from site,winxp pro,but no output so I took it loose and connected a scope, should I be able to read these outputs with out a dac connected to it and does it seem to have the drivers loaded correctly,I am about ready to load linux ubuntu newest and try to see if it will find and load it,and of course play it!
Thanks ,
No Smoking,lol a play on burning up perfectly good parts,lol
Thanks ,
Hi KlipschKid,
I got it to work had 3 problems all nipping at my toes,lol.
A bad switch ,headphone cord(don't loan headphones to your kids),
and wrong drivers,
To make a short story out of this,IF you have one of these boards ,load the setup file form the site first and it will tell you when to connect the board,I never could get windows to find the correct driver manually,lol.but it is working now,sounds good in hardware,now the fun part software,,,,lol.
Thanks to all that post,it helped!
NS
and wrong drivers,
NS
You'll need to find the pin for spdif in, feed it ttl level spdif, and get a driver and firmware to control it (Asus' should work). Here are the pins.
Can you find it ?
If not, quit now.
It's pin 40.
It can be done as this photo from Asus' Website for the Essence One shows inputs, but I wouldn't attempt it because those pins are too small for me to work with. How about you ? Do you know a device with an easy pin out connector ? Is there one on the market ? Have a look on Ebay and Taobao.
ASUS - Multimedia- ASUS Xonar Essence One
Can you find it ?
If not, quit now.
It's pin 40.
I don't think Asus use those pins so you're probably not going to succeed ; unless you can find firmware / driver to control those pins.
ASUS O!Play Essence One PCB | Flickr - Photo Sharing!
If anyone wants to isolate the output of their CM6631, there is a group buy started on this thread :
http://www.diyaudio.com/forums/group-buys/227502-amanero-isolator-reclocker-gb.html
and a little more here:
http://www.diyaudio.com/forums/digital-line-level/147817-ackodac-based-es9018-64.html#post3301635
roygbiv - email C-Media - tell them you want to develop this aspect of their IC. They might send you the tool if you sign an NDA. If not, then the spdif should work.
- Digital Line Level
- CM6631 usb audio interface .... any good?
