Closed or vented?
Hello everyone,
I'm a but confused right now. This because I recently measured 4 drivers from Jamo (type EC 141 A), and according to the results these drivers should be mounted in a closed box:
Fs: 55.6 Hz
Qms: 4.05
Qes 0.89
Qts: 0.73
Vas: 18.2 L
However, I used two testboxes of about 50 L, one completely closed and one with a 'vent'. The closed box really sounded bad (no low end), the 'vented' box produced nice bass with these drivers.
I can hardly imagine that the measurement results aren't right, because I repeated them several times. However, I don't like building-a-box-and-hope-it-sounds-good, because i want to know what I'm doing.
Could anyone explain the difference between the measurement results and the 'soundcheck'-results? Or does anyone know what type of enclosure to use to get the most optimal results from these drivers?
best regards
Erwin
e-side said:
No, I only measured them in free air (just for TSP). Thanks for the advice!
BTW, will a dipole with these (small) drivers sound nice?
best regards
Erwin
To be honest I can't speak to those specific drivers in regards to a dipole/open baffle design, but consider these variables:
- Do the drivers have relatively open baskets, to allow breathing room for the rear wave?
- Is your listening room large enough to accomodate moving the speakers 3-4 feet out from the rear wall to achieve the dipole effect?
One thing for certain is, if you go open baffle with relatively small drivers you will lose the bass you are experiencing with the ported boxes you have now. So you will need to supplement with a sub or subs to get it back. You will also likely need to deal with crossover and equalization issues with open baffle. Have you read the Linkwitz site?
Since you have measuring equipment and test boxes it should be relatively easy to mount the drivers on an open baffle and see what happens, but definitely measure again. It can't hurt to try a few different designs before you find the one that sounds best to you, and use your measuring equipment to tweak it until it's "perfected."
Hope this helps!
diyAudio Moderator Emeritus
Joined 2001
E-side:
You mounted all four woofers in a single box of 50 L?
Okay, for the vented box, can you please tell me:
A) The inside dimensions of the box. If not easily available, the outside dimensions plus the thickness of your building material.
B) The position of each woofer on the face of the box.
C) The position of the port on the box.
D) Diameter and length of the port.
The reason for all this is that I plan to run Martin J. King's software on your vented box and see what it looks like. I need this info, though, to do this.
Finally, I know this sounds elecmentary, but how is your wiring in each case? If you hooked all your woofers up in parallel on one of the boxes, you're going to strain your amp. I'm sure you know that, but it's worth it to check the wiring anyway.
- Not really. I don't know exactly what should be considered as 'very open', but there isn't very much space left.
I agree that the low-end will be reduced much when mounted in an OB, so apparently it isn't the most ideal enclosure for these speakers.
kelticwizard said:
E-side:
I'm sorry for my previous unclear explanation, but for the testboxes I used one woofer for each testbox (1 woofer for a single box)
A) The inside dimensions are 19.8 x 97.5 x 26.9 cm (WxHxD), or 7.92 x 39 x 10.76 inch
B) The woofer's center is positioned at 72 cm / 28.8" from the floor, and 9.9 cm / 3.96" from the side (vertically in the middle of the front panel)
C) The 'vent' is just a hole in the back panel of the box, positioned at 9.5 cm / 3.8" from the floor and 9.9 cm / 3.96" from the side (vertically in the middle of the back panel)
D) Diameter = 8.3 cm / 3.32", length=1.8 cm / 0.72"
Because there's only one woofer, the impedance for the amplifier is about 8 Ohms.
Thank you all very much for your help!
best regards
Erwin
I believe your venting is giving you about 20Hz more bass extension. It is also probably giving you a bit of a hump around 80-100Hz which can sound "punchy". The sealed box works out to a system Q of roughly 0.85, if you driver params are correct.
Play around with this applet:
http://www.linearteam.dk/default.aspx?pageid=newdriver
(The site also has a vent calculator.)
This will give you some intuition about what is happening.
kelticwizard said:
And, save for the port, the dimensions of the sealed box are the same?
If not, I would appreciate the dimensions on the sealed box as well. Also, could you approximate how much stuffing, if any, you used in each box?
Dimensions are the same, and I didn't use any stuffing.
I'll have a look at that site. Thank you and kelticwizard for your kind replies.
regards
Erwin
Joined 2001
I forgot to ask-what size are these speakers? And what Bl, ( I might be able to figure that one out from the other specs).
In the tall skinny enclousre you have, I would think that box effects would be pronounced.
Can't find Jamo EC 141 A anywhere. Your box is 8" wide, suggesting an 8 inch, but the 141 suggests somwthing closer to a 6 inch. Hmmmm
I don't need the full Sd, (cone area), just the diameter of the speaker frame.
The diameter of the frame is 18 cm or 7.2", the diameter of the speaker cone is 14 cm or 5.6" (including surround)
Re = 9.4
Cms = 2.84 x 10^(-4)
Mms = 0.0289 kg
Bl = 10.33
best regards
Erwin
Joined 2001
Erwin:
Excellent. I shall give you the Martin J King simulations later today. It's 7:33 AM here right now, (snore snore). :)
The Martin King software is better than other software for the reason that it takes into account the shape of the box and the position of the speaker and port in that box, both of which can affect response, sometimes drastically.
Takes a little more effort to use, but it is worth it.
Joined 2001
Okay, here are the simulations.
Just as I thought, the position of the woofer plus the shape of the box do come into play-something only Martin J King's Mathcad programs can chart. So the graphs will be different from WinISD, BoxModel, UniBox, etc.
Here is your vented box, unstuffed. The vent you have tunes the box to 55 Hz.
Red line = Vented box.
Dotted blue line = theoretical response of closed box of same volume.
Joined 2001
Here is the same box, same stuffing density, only tuning frequency changed to 42 Hz. We do this by making the port length 3 inches. Diameter stays the same.
Bass cutoff now extends down to 37 Hz. Very improved.
kelticwizard said:
Hope all this helps. :)
Sure it does! Thank you very much for your kind and detailed help!
I will have a look at MJK's spreadsheets so I can try out a couple of things too.
BTW I'm still not sure why these drivers work better in a vented box, because they have a quite high Qts. According to the EBP these drivers should be mounted in a vented box, but the high Qts says that closed would be a better option...
One last question: What kind of stuffing should I use? I already tried to use MJK's TL sheets, but I'm not sure what kind of damping to use. For closed boxes, I usually use polyester wool from visaton (http://www.visaton.com/english/artikel/art_155_1_40.html)
. Is it suitable?
Thanks again.
best regards
Erwin
