If you want to replace the oscillator there are two products on the market.
Tentlabs www.tentlabs.com
and LCAudio
http://www.lcaudio.dk/com/index.php?page=4&PHPSESSID=ecd1ae6f3be4fe71558f4bca00c416fe
Which is the best? We have had and long long thread about this but we couldn't come to any conclusion. LCAudio's look coolest with 4-layer pcb and a blue LED!
and LCAudio
Hi Hacknet,
Well there is also the Audiocom clock, the Trichord clock, the Netaudio clock, the clocks from www.audiotuning.de , the Gruensch clock www.gruensch.de , the French Maxi clock by Antileon http://www.tnt-audio.com/clinica/antileon_e.html , the G & D Transforms clock I never did get hold of, the K.K. Ho clock from Hong-Kong, Jocko's DIY clock as posted on this forum and the DIY KWAK-CLOCK. You can download the schematic here:
http://www.diyaudio.com/forums/showthread.php?postid=199928#post199928
Building?
Except the latter two all other clocks are ready built. This is a DIY forum.hacknet said:thanks. is there any other way instead of building these circuits?
Drop in Replacement
Hi Hacknet,
I am sorry but I am afraid you confuse the crystal with the clock.
A clock is a crystal oscillator consisting of a crystal, a active circuit with a transistor or FET and very often a low noise power supply regulator.
I know of the AhTjoeb offering a low jitter crystal whatever that may be. As Jocko said low ppm does not say anything; low jitter, low frequency deviation......? In my experience the active circuit is much more important than the crystal. Also a SC-cut crystal that seems to be the best for low jitter is VERY expensive, something like US$ 120.
hacknet said:I was hoping for drop in replacements... eg, a lower ppm clock that i could just use to replace the original one.
Hi Hacknet,
Re: Building?
Hi
The heart of the TentLabs clocks is available for DIY as well
cheers
Hi
cheers
- Digital Source
- Clocks
