Somewhat related... What can I use on tube pins as a lubricant, or just clean the pins? Yesterday I swear I was going to crack a 6CG7 inserting it into a brand new Belton socket, I had to apply at least 30 lbs of force it seemed. Same for removing it. I think the Deoxit company might have a product with both cleaner and lube that won't insulate, I'll have to check.
For glass I used Sparkle window cleaner (the purple stuff) it has no ammonia like Windex does and I just stayed off the lettering if it was coming off. Some tubes had real durable lettering, some had paint lettering but the important tube number was etched, other tubes had lettering that you could remove just by looking at it the wrong way!
Deoxit F5 should work well, but I'd probably just use WD-40 or something similar.
Thanks. WD-40 is my favorite for everything, it's a very unique product formula. I use to keep my mailbox and truck locks from freezing up with ice in winter, I use it as aluminum cutting oil on the CNC and drill press, just about anything not pots though. Years ago I used it on distributor caps. No reason to believe it won't hurt wiping a little onto tube pins.
- Tubes / Valves
- Cleaning tubes...
