We are doing project work on class D audio power amplifier. For that we are using TAS5261 IC and pga2310 using as a volume control, tpa 2310 as a pulse width modulator.
Sir, we are suffering from simmulator for this and also HOW TO INTERFACE?. And also circuit diagram.
THANKYOU.
THANKYOU.
simulator require.
We are under taken the project "class D type audio power amplifier "using TEXAS IC TAS5261.And we are interfacing the PGA2311(VOLUME CONTROLLER) and TPA2000D1 with TAS5261. We require "simulator software " for this project.so i request you to please help me.
Re: simulator require.
That part about the TPA2000D1 and TAS5261 sounds so familiar... I seem to remember seeing something like that before... A search for "TAS5261" in the class d forum should return something useful.
As far as the simulator software goes, I really doubt you'll find someone willing to help you out for nothing.
surya krishna said:And we are interfacing the PGA2311(VOLUME CONTROLLER) and TPA2000D1 with TAS5261. We require "simulator software " for this project.so i request you to please help me.
Re: pcb design
By learning to route PCB yourself?
surya krishna said:how to get it?
Re: Re: pcb design
Bad girl !
Surya,
you could go for TinyCAD in order to draw the schematic and export into a netlist.
For layouting you could use FreePCB.
Bad girl !
Surya,
Re: Re: Re: pcb design
ChocoHolic
EVA is a girl???
cracy and great
FUMAC
ChocoHolic said:
Bad girl !
Surya,
ChocoHolic
EVA is a girl???
cracy and great
FUMAC
Hi, my reply isn't to turn you down but I think you are trying t obuild something quite above your level, first because if you don't know what soft to use you obiusly haven't been on designing boards quite much I'd recommend you protel99 or livewire kit though, and secon you haven't been able to find any application information.
Well to find som you should look in texas aplications pdf there is always some design of their products.I'm shure you'll find some there.
I'd sugest you to start with something easier for example, the one I've studied, the TAS5100, there is also a design including board.
Any way hope you make it class D texas amps are wonderful, they don't waste enery like valve amps or heating like he..ll as class A and the bes of all the signal is THE ORIGINAL one that came frome the source bye bye noise. nice huu!
Look for this app note on texas cause I couldn't upload it for you
"sleu010a5100" there is a whole board designed, not too complicated 2 channels 30W, analog or digital input.
Bye
Bye
Re: tas 5261
These forums are not to be used in the manner you are attempting to use them. Please do your own work and stop spamming the forum with requests that someone do it for you.
surya krishna said:require simulator for tas5261
- Class D
- class D audio power amplifier using tas 5261 IC.
