Clarion Lcd Broken??!!
hello, i stripped a clarion vma6491 lcd panel...(after 2 months of use)on an overhead for tv+xbox.today it suddenly started to smoke after 2 minutes of the ohp being on.then no image was viewable.but the red power light was on but still no pic.what is this panel worth???is an overhead projection panel a good investment and could something like this happen to it.
http://www.macworld.com/search/images/zarchives/articlelinks/h-l/lcd.panels.speed.tests.gif
look at this website, and give me your opinion on which projection panel is the best for xbox gaming and tv for value+quality(not necissarily from the site.
THANKS
hay, lemme guess u disconnected the ballast didn't you? i did that to my first lcd which was really annoying, good news is that it can probably be repaired for less than $1, if its the same thing that happened to mine you've just blown a transistor, can you find the componant on the board thats smoking and take a pic of it or describe it, should be black, have 3 legs and have a metal back plate, if you can read the info off of the front of it you should be able to get a replacment.
Ryan Edge
nah, i wish that was it but i dont think so....
since my panel is broken i want to get a projection panel and not risk another lcd...i kno there is a bunch of post and threads on projection panels ex-good panel/bad panel but i would like your opinions on the best panels to get beside sharp qa-2500(too expensive)i think either nview z215 or z250...what do you think is the best panel in your experiences...thanks!
dengez
