Hi dbagchi,
I tried to use your simulator. It looks good, but when i wanted to put inside the MPSA06 specs, as from ON-Semi, it was not possible to insert, for example, 1234 e-15 or so on, since it put 123415 without e-. Is it my mistake or what? I'm not an expert in spice simulation, I'm a soldering man. Anyway this software could be very very helpful if there will be a complete and big library. On the other side I would like not to spend a lot of time in trying to find and to put all the specs I need. In such case perhaps it will be better to build the circuit and check it in real how it works.
BR and thank you
Milo
BR and thank you
Milo
