Circuit diagram for the Philips F7430
Hello everbody,
Can anyone help me with the Philips F7430?
The arm lift doesn't work, and i think it has to do with the electronics.
So if anyone can help me get the manual and/or circuit diagram that would
be great.
I do have the usermanual and servicemanual
If you still want them I have both.
Textpart in servicemanual is in Dutch but schematics and so on are useable in any language.
I could translate Dutch questions to English.
Usermanual is multilanguage.
I just repaired one... Arm didn't go down.
Cause bad contacts in the Processor connector.
I exchanged the connector for a good one and player is OK again.
Greetings, Peter
Greetings, Peter
Hi Peter,
I just receibed a used one, and the tonearm is not lowering also.
When opening the box I half broke the tray in/out mechanism, which I hope I have repaired.
I'd appreciate it if you could send me an indication of the faulty part (how to identify it on the circuit). I don't speak dutch at all.
I would also appreciate any aditional info, for example on how to change the headshell, as the tip in mine seems broken or unexistant.
By the way, do you think that this model is worth the effort of repairing?
Would you recomend any cartridges?
I was considering to change the stock platter for a heavier one. Could it be an improvement
my email is despinos at yahoo.com
Thanks anyway and regards
David
I'm having the same problem with the Philips F7430. The arm doesn't go down. Peter Visser, what do you mean with the Processor Connector exactly?
Je mag me ook in het Nederlands antwoorden als je wilt ;)
Or is there someone else willing to help me?
Thanks in advance!
