choosing input valve
If the imperfections are below audibility, how is that "handicapping"?
OK, so how do you know when it is below audibility (at the design stage I mean, without having to build it and find out the hard way)? As a know-nothing newb, can I only get below this 'good enough' threshold with a 6SN7 running with a CCS? Or would an ECC85 with resistive load do just as well?
I don't have measurements on an ECC85, so can't say. I've done enough testing on 6SN7 line stages to know that IF they're designed properly, I can't hear them in a bypass test. MJ's versions use mu followers, mine use CCS plus cathode followers, but we end up with pretty darn similar specs (0.00x% THD at 2V out).
MerlinB said:
And then often use transistor CCSs to try and scrub away all the pesky nonlinearities of valves!
A CCS load allows the true linearity of a triode to appear, if it is a linear triode (such as ECC83/12AX7).
The dynamic range problem was introduced by you, when you suggested that we could avoid the inherent non-linearity of BJTs by severely attenuating all signals to below 1mV. This would ruin S/N ratio, so I was surprised that you suggested it. However, you seem to be fixated on non-linear distortion as the only measure of an amp. An amp with 0.000001% THD but 25dB S/N and 300-3kHz bandwidth would sound horrible - a bit like a good telephone line.
