My Chinese is bad, but the 6N1 data sheet seems to have the following data:
u about 35
Transconductance about 4500 uMhos
Plate Resistance about 7700 Ohms
Heater 600mA
That is very similar to the many Svetlana 6N1P that I purchased before they were no longer available. I like and use the Svetlana in some amps.
The 6DJ8, and ECC88, etc. are not like that at all.
u about 33 (the closest similarity to 6N1 and 6N1P)
Transconductance about 12,000 uMhos
Plate Resistance about 2750 Ohms
Heater 365mA
They also have a much lower maximum plate voltage, as well as a lower maximum filament to cathode voltage rating.
6DJ8 has 2 filament to cathode voltage rating, one voltage rating for triode #1, and another voltage for triode #2
You mileage in your amp may vary.
Plug and Play tube rolling can become Plug and Pray.
u about 35
Heater 600mA
Heater 365mA
Sometimes there are surprises in tube data specifications.
1. From the RCA 6DJ8/ECC88 and the Sylvania 6DJ8 Data Sheets:
Heater-Cathode Voltage: Unit No. 1 Unit No 2
Peak Value ———— 150V
Average Value 50V 130V
Unit 1
Plate Pin 6
Grid Pin 7
Cathode Pin 8
Unit 2
Plate Pin 1
Grid Pin 2
Cathode Pin 3
This tube was made for Cascode operation, but be careful:
Unit 1 is supposed to be the bottom tube in the Cascode (or SRPP)
The highest average voltage on Unit 2 cathode is 130V.
The highest Peak voltage on Unit 2 cathode is 150V.
The New Old Stock Tubes should not be used above the old ratings.
2. One new production of a tube that is Very similar to a 6DJ8/ECC88 (the E88CC) has the following limiting specs:
U+k/f- = 120V
U-k/f+ = 60V
Unit 1
Plate Pin 6
Grid Pin 7
Cathode Pin 8
Unit 2
Plate Pin 1
Grid Pin 2
Cathode Pin 3
U+k/f- = 120V
U-k/f+ = 60V
