check my simple circuit
I want a solid state phase splitter in a tube amp. I can't use a tube, because my transformer can't supply more heater current.
This is my first solid state phase invertor, so please check if it will explode, do nothing useful or work.
First question, only because I don't feel like looking up the datasheet, will those transistors support a Vce of 220?
Ok, you've got 120k of resistance per leg. From a 220 volt source, that's 1.83mA of bias current. That's reasonable. But the collectors of your Qs is at 37Volts. This means your +/- swing will be limited on the - side. You should try and bias the collectors at 1/2 VCC.
Secondly, since you've got 100k of collector resistance, your gain is going to be pretty high (gm*Rc ~ 7800) so your input signal level will be very sensitive.
Do you just need a phase splitter? You might want some emitter resistance. If you make Rc and Re about equal, you'll have something that does a gain of 1. Maybe split up your 100k into 2 50ks. You'll have to adjust your bias a bit.
i was thinking of a similar thing in my post http://www.diyaudio.com/forums/showthread.php?s=&postid=353069#post353069 , ..although this would be close to the input (maybe preceeded by a tube buffer)
the downside is that you would require a +/- 15V supply for the DRV134 line driver / phase splitter opamp
if tube heater current is your only limitation, why not just buy a small filament transformer to address that issue?
the one (really dumb and naive) question i have about this opamp (not being a SolidState DIY'r) is "what governs the output voltage of the line driver, the input or the supply voltage?"
regards :)
I tried simulatin the circuit using LTSpice, but I didn't succeed in that. I just couldn't get 2n6517 to work in the program. So I simulated it with the demo version of circuitmaker.
I would replace R3 with a current source.
I used a current source made of a lm317 regulator. It simulates a lot better than a plain transistor in the tail position. I can't use it in the real world though because it needs more current going through it to work well. What kind of current source would you recommend?
In my simulations, gain is 31 (with a current source as tail) I think this is ok, the tube counterpart in fender/marshall/vox amps has an even larger gain.
Vce max is 350V for this transistor
