Double layer PCB, on FR4 support, with over 95% ground plane on each side.
The best layer synchronizing (over 99,5%) could be done it from Eagle files.
Below is the BOTTOM layer of above double layer pcb.
Below 4 pcb's done it on tinned CEM3 suport , have been manufactured for our forum friend RCruz (Ricardo).
I hope that he will enjoy my releases, as soon he will receive them.
Hi Ricardo,
Thanks a lot for your appreciation.
Please feel free to post here your "populated boards". (solder sides + components sides).
Because our communication was perfect one, I'll try to help you with next PCB projects, if my available time allow this.
All the best,
Mihai
All the best,
Mihai
Thank you so much for your help Mihai. The boards look very good. Will now start populating and after I will leave a subjective comment here
Cheapest_PCB on CEM3 professional support.
Cutting of boards are FREE for any cutting type (linear or curved)
I offer you for free:
-TINNING (only for CEM3 support)
-DRILLING
CEM3 has min. 22 um ( max.25 um)
-DRILLING
Below can be found the SILKSCREEN (components mask) of above round pcb's.
Cheapest double layer PCB boards on FR4 support.
The pcb's are TINNED on both sides.
Below can be seen the BOTTOM layer.
Below can be seen the TOP layer of above shown boards.
Hi Ricardo,
First of all, I thank you, for posted pictures in my thread.
You did a great job.
I hope that the "sound" is near hi-end, and you'll enjoy for your realised amp.
We'll be in touch for next pcb projects.
All the best from Romania,
Mihai
Mihai
Look what I did with your boards Mihai.
Very nice work, the copper is thick and does not peel off even if I desolder severall times.
Thank you so much.
80 pins adapter - FR4 - tinned
Dear Namcir,
I have not available time to design the pcb's.
Always I manufacture the pcb's ( as presented boards in this thread) , from different ready designed boards.
Files accepted: Eagle, ExpressPCB, DipTrace or pdf , jpeg ( at least 600 dpi)
Thanks for your understanding,
Mihai
Mihai
Cheapest PCB's on CEM3 with FREE TINNING.
DRILLING is FREE for CEM3 and FR4
Cheapest PCB's on FR4 support
The TINNING is also FREE for FR4 with 1 mm thickness ( NOT for 1,5 mm FR4 support)
The FR4 support with 1 mm thickness has at least 80% transparency.
- Vendor's Bazaar
- Cheap printed circuit boards starting with 0,0375 Euro / cm2
