Cheap 150watts amplifier
Oh dear not this one again! You will not get 150 watts out of this amplifier. The SOA of the out put transistors will not allow it and they WILL fail. If you are lucky you may get half that 75 watts, but you will need a huge heat sink. This was originally "designed" by a guy called John Fisher/Tyrone and has never been tested at 150watts. See here: Cheap 100 to 150 Watt Amp
SIGMA 40 W BASE ON Philips origanal 40 wats ampli
hi all I have old Philips 40 WATS amplifier PCB with component install it has make some changes to original circuit
OK Sakis can you have PCB Layout for 60-80W Power Amplifier by Rod Elliott
It is been said way too many times ... What i do with the P3a is for personal pleasure only ..the specific lay out serves my criteria and of course i am not willing to give away layout or pcb .
feel free to design your own ...or buy dirt cheap original from Rod
Kind regards
Sakis
