francorovereto said:They offer me a combination of poplar plywood (for side/ rear panels) and russian birch ply (for small internal panels) for a reasonable prize... better than mdf, isn't?
With poplar could return on the Sachiko project...but I'm not sure it will sound so good. Maybe over-bracing the panels would be an option?
We have used the russian ply interchangably with BB. The poplat ply is probably pretty good too... as Scott mentions one has to worry a bit about voids -- but i'd rather use ply with a few voids than MDF.
Extra bracing never hurts -- in sachiko that means an end-on vertical brace on the back and a horizontal onr in the mouths -- just make sure they are off-centre.
dave
francorovereto said:Cement based layer in a cabinet?
Bob
hi,
the context for the horn width of 45 cm was that they don't need any electrical tuning (especialliy in the midrange). A test of the AN8 in a acousta cabinet (lowther) would be the best result (that wrote a german hifi-diy-magazine -> I hadn't read this article, I only read this in the other forum).
So, and here both sachikos
Greetings Armin
Greetings Armin
Bob Brines said:
Bob, what is the acoustic material lining the cement layer?, can I get it from Homedepot or Lowes?
gychang
gychang said:what is the acoustic material lining the cement layer?,
Fiberglass insulation.
dave
gychang
The product is Armstrong #420 acoustic ceiling tile. It comes in 2'x4' panels with a white plastic sheet on one side. It is becoming hard to find. The same basic rigid Fiberglas is used in the HVAC trade to line air ducts. A local contractor might lead you to some.
Bob
- Full Range
- Chassis for Sachiko
