Re: V3proto
I built it fully complementary because that is the way I think it is best. I think fully complementary is better than CCS or plain resistor or bootstrap. If you want to change it to non-complementary, that is up to you. You should build it the way you think it is best.
lumanauw said:Which is better, replacing Q8-Q10 with CCS or plain resistor (or bootstrap maybe?) if I wanted single differential like I told you above?
fdegrove said:Eh, eh, eh....That wouldn't work either...no matter how small it is there will allways have to be a distance between input and output.
To bridge a distance takes? Time.
To charge and discharge a capacitance takes times, to charge a space takes time....even in a vacuum.
To make one triode different from another takes a distance between the elements...and so on.
Yup.
You still have that stopwatch?
*tick-tick-tick-tick-tick...*
Seriously, I think Charles was talking from an ideal model POV. Not necessarily a real situation.
Mmmm. But an ideal model wouldn't include the parasitic capacitances that he mentioned now would it?
Picoseconds...that's a pretty short distance in time, isn't it?
Mmmm. What was the name of that woman who was the first female Admiral in the US Navy? She was big on computing technology and used to carry little lenghts of wires around with her to demonstrate what a nanosecond was, what a picosecond was, etc.
She'd appear on talk shows, whip out a little length of wire and say "That's a picosecond."
She was a pretty cool old broad.
se
SY said:Grace Hopper. Amazing person, she was.
Very good, Gracehopper. When you can take the pebbles from my hand...
Thanks!
Geez, attachments of graphic images have to be downloaded now?
*sigh*
We're all getting old....
I first met Grace Hopper in '75 at a computer conference. She was 'only' a commodore back then. We were both sitting in the back of a lecture room, and I asked her if she mind if I smoked, to which she replied 'not at all darling' and promptly whipped out her pack of Lucky Strikes....
An amazing women; Congress had to authorize her military retention on a yearly basis as even back then she was about 20 years past mandatory retirement.
http://www.google.com/search?q=grace+hopper&sourceid=mozilla-search&start=0&start=0
se
No, it was nanoseconds she carried around and handed out.
I have one of her nanosecond wires somewhere since she
held a lecture here in town maybe 25 years ago. She also
had a microsecond but she only showed that one. She had
a whole bunch of nanoseconds to hand out, though, and
claimed she had stolen the wire from a phone repairman
in Pentagon. She also told how she had spent at least half
an hour in swedish customs trying to explain nanoseconds
and microseconds, and add an admirals hat on an elderly
greyhaired lady to that and I can understand why they
were puzzled.
The story behind these wires was that a long long time ago
a fellow programmer sometimes used to tell her that she
could save a microsecond here and there in a program, and
she used to answer "so what, I don't know how much a
microsecond is anyway. Can you show me one?" The fellow
couldn't, but eventually Hopper herself realized it could
be visualized by cables of approriate length.
She must be one of the funniest lecturers I've ever heard,
and probably the funniest and most unorthodox admiral
ever in the US Navy.
OK, I spent a little time measuring stuff where I sorta knew the outcome in advance. Bottom line: there's a difference of many orders of magnitude between delay time in the transit time sense and time constants from RC charging. The former are REALLY small: I can measure down to about 4-5 ns with my crude setup and the delay through a common cathode voltage gain stage feeding a cathode follower is well below that. The risetimes are another thing, but they're just ordinary poles of the sort well-accounted-for in standard control theory. I'm still not sure what the philosophical objections to feedback loops are.
Mixing the two time constants together, whether in a long explanation or in quick comments, is the source of the confusion and rancor, IMO. One is very, very short and a constant delay, the other is rather longer and has exponential characteristics.
SY said:OK, I spent a little time measuring stuff where I sorta knew the outcome in advance. Bottom line: there's a difference of many orders of magnitude between delay time in the transit time sense and time constants from RC charging. The former are REALLY small: I can measure down to about 4-5 ns with my crude setup and the delay through a common cathode voltage gain stage feeding a cathode follower is well below that. The risetimes are another thing, but they're just ordinary poles of the sort well-accounted-for in standard control theory.
What exactly were you measuring?
Does 4-5ns represent the delay between the input signal and the feedback signal across the cathode resistor (which is the feedback element)?
The philosophical objections I've seen most often are that feedback is always "late" (i.e. that it can't correct for what's happening "now") and that it produces higher order harmonics.
se
PMA said:Anyway, funny it would be to consider 4-5 ns delay having any disturbing effect in audio circuits
Well, it will affect the 450450th harmonic of a tuning A.
Steve, I'm injecting (and monitoring) a square wave into the grid of a common-cathode stage, this stage is direct-coupled to a cathode follower, and then I look at the output of the cathode follower. Looking at leading and trailing edges, the point at which the output signal starts to change is less than 2 ns after the corresponding point of the input signal- i.e., I can resolve this to 2 ns and any difference is below my resolution limit.
Now, the SLOPE of that change is indeed different between input and output, but the time point at which the change begins is identical within measurement resolution.
Zero surprise here, since feedback WORKS when it is done in conformance to proper and well-understood criteria.
Well, again, I won't and can't argue philosophical decisions. I'm just interested in doing easy stuff to get a gut-level understanding of the magnitudes involved. I really do appreciate your explanations, and you motivated me to spend an interesting and enjoyable hour or two.
Charles Hansen said:Never said it didn't work. Just said it sounds bad.
May sound bad if the circuit not done properly. Unfortunately that is true in 95% cases. But it does not mean that feedback sound bad. It was the bad designer who had done it.
FWIW, you can have the best circuit in the world (which one is that anyway) and if you apply too high levels of FB the timbre of the instruments will have subtly changed, spatial clues will have gone down the drain too.
From that perspective, yes FB CAN be a bad thing.
How much is too much and how you'd measure what you'd be hearing, I don't know but timesmear seems to play a role here.
fdegrove said:FWIW, you can have the best circuit in the world (which one is that anyway) and if you apply too high levels of FB the timbre of the instruments will have subtly changed, spatial clues will have gone down the drain too.
how abou the reverse: take the best circuit in the world, reduce the level of feedback in it. What will happen to the timbre and spatial clues? Will you guarante an improvement? if you cannot, wouldn't you have to conclude that LESS FB can be a bad thing, based on the logic above?
What does that mean for this discussion?
I thought anything CAN be a bad thing.
You're already assuming there's feedback.
Maybe one should say circuit topology for some to keep a perspective?
Charles,
I have several question about your design.
1. R3,4,5,6 in the gate of differential pairs (1K5) + mosfet's input capacitance (TO-220, about 1n7) will produce lowpass filter. Is this on purpose? To limit bandwith? What is your main goal putting 1K5 in the gate of differential transistor?
2. R53,54,55,56 is connected to output. It gives somekind of feedback, modulating the drop in R61,62,63,64, instead if we put those R to ground (fix the drop in R61,62,63,64).
Somehow personally I think those R can be to ground to give constant drop at the folded cascode. But you are experienced designer. What is your reason, putting those R relatively to output, so the folded cascode is not at a fixed value?
fdegrove said:(...)How much is too much and how you'd measure what you'd be hearing, I don't know but timesmear seems to play a role here.
Err, what exactly is "timesmear"? Is this caused by parasitic flux capacitors or something?
- Charles Hansen come in please
