What's up guys, I have an idea for a center channel that I want some suggestions on.
I plan on using 2 Dayton RS100 side by side in a tiny enclosure. They would play 20khz down to around 100hz
Now on both sides of the Dayton enclosure would be a Skar IX8 woofer in about a 0.3cf enclosure.
So, good idea or bad idea?
Suggestions?
https://www.parts-express.com/dayton-audio-rs100t-8-4-reference-woofer-truncated-frame--295-338
https://www.skaraudio.com/collections/ix-series/products/ix-8?variant=17677557121
Thanks all.
Suggestions?
Thanks all.
Even a horizontal TM only ( i.e. not a conventional D-Appolito) would probably give better results.
FWIW, I've been running single driver aka "full range" centers for over 5 years now, and have been happy with the results. Drivers are timbre matched to the floorstanding L&R mains, although the center enclosure is sized for convenience. As the center is crossed over to the summed mono LFE channel at 100Hz, the smaller enclosure isn't detrimental to bandwidth / SPL in my moderately small (340ft ^2) room, and at normal listening levels well below THX reference standard.
Why do you suggest 1?
Because you`d experience lobes in the horizontal plane, as close as +/-15 grad. The somewhat modern concept of a center channel is an expensive marketing creation full of flaws. Use one as Dave suggests, power handling is the least concern.
- Center Channel Idea
