cd6000 fault
Good sirs of diyaudio. I require your assistance.
My Marantz cd6000 ose limited edition is no longer working.
Fault description:
screen does not display, no power light, none of the control buttons on the front work, remote does no work.
When powered on I can hear the transformer power up.
I have had a multimeter on the back of the front panel at the point which the "ribbon" connects. The following voltages were measured.
Top row of pins 0v 0v 5v 5v 0v 0v 0v 0v 21.7v
bottom row of pins 0v 0v 1.2v 5v 5v 5v 5v 21.7v 26.2v
Does anyone have the service manual for this model to check the values?
Has anyone experienced this problem before?
Has anyone got any ideas where to start to find the problem?
Kindest regards
goodlife
Fault description:
Kindest regards
goodlife
Hi.
Alongside the transformer are 2 small round devices. Fuses !
They supply the +5v and the 10v supplies.
Check them with your meter - they are a little undersized
goodlife,
I have the cd6000 service manual. Its 5.5mb drop me a line and I'll mail it
what do you mean you can HEAR the transformer power up? It does sound though, like your not getting any juice to the front board.
I'm sure you've tried this already but make sure everything's properly connected. I lost the left channel on mine, turned out to be due to the glue on the HDAM had gone and it had come loose. About the easiest fix ever... :)
Andy
Fault description:
Kindest regards
goodlife
Hi.
The voltages look OK
[ see diagram of connector]
top row is even nos.
bottom row is odd nos.
26.2 = pin 1
andy
