CD304MKii output stage question
I'm modding a Philips CD304 MKII and am looking at the output stage.
Having seen many TDA1541 based player schema's I haven't seen this before (see picture). There is even a special regulator on the decoder board for this. To me being in the signal path it looks like a bad thing.
Can someone explain/advise?
Wouter
Administrator
Joined 2007
Perhaps it is an attempt to reduce offset errors in the NE5532 and following circuitry by injecting a current into the virtual ground point.
How does that resistor and cap (the 2K7 and the 10uf cap) affect the "noise gain" of the opamp by it "throwing away" some open loop gain ? Sonically that can be beneficial in the right circumstances but I'm not sure how it works out in this configuration as an I'V convertor.
