Cathode Follower confusion
Allen Wright said:
But you could make a horribly badly designed Cf and have the cathode at (say) only 2V above ground, and then of course it can't swing enough to follow a CD player signal. I have seen exactly this is a tube output Chinese CD player - HORRIBLE 2nd harmonic distortion - yet some people defended it's sound when I critiqued it!
Wasn't a Shanl!ng was it?
1.6V across the bias resistor guys.
I changed the tube back to 6N6P with a current of 14mA.
Sounds very sweet:D no complaints.
I think the 6N1P may need more current. Didn't sound so good at 10ma IMHO.
I want to try the 5687. Got to look at the pin diagram and re-wire I believe.
Thks Merlinb.
I've got a virtual CT running at the moment. Great to know I can use the pin 8 as a CT instead.
Was a bit concerned as the 5687 seems to glow much brighter than other tubes ( thought I had them wired up incorrectly). In fact as I experiment with various tubes they do all vary quite a lot.
I tried some 5963's last night (same config as 5687) and don't glow half as bright.
