Ok, while I'm waiting for the parts to arive, I am building and rebuilding this silly little 3875 amp over and over in my head... bet I can do it without the circuit diagrame by now...
Now as I had this whole amp constructed and suspended in space (in my mind) It reminded me of a clear casting-resin paperweight I made in primary school in class with components in...
So I was thinking, asuming I could make a jig/mold to encase the whole amp and all its components (except the powersupply) in a resin square... I could even do it so the bottom of the chip sits flush with a side so it could still screw into a powersupply
Do you think it could work, in terms of dissapating heat, so that the resin would sorta act like a big heatsink, drawing the heat out evenly, and provide a larger surface area for cooling of.
or do you think it will end up as another paperweight.
we are talking about a unit here that will not be repairable...if it breaks, its a paperwieght.
I cant see a significant reason why you shouldn't do this.
The chips will need heatsinks. Use the heatsinks to form the 2 sides - have the chips mountedto the heatsinks before you begin.
Then using some sheet acrylic, make a u shape that will form the mould. Secure on the outside using some hot melt glue.
Now is the tricky bit - suspend the power supply jacks, the RCA inputs and the speaker outputs from a jury rigged frame, at the final level of the back of the amp. Fill the mould with resin to the finished level on the back, and wait for setting.
carefully peel the mould from your unique crystal gainclone...
Do let us see the finished product!
Owen
Owen
Just google for Clear casting resin, the stuff looks like glass when you are done... Oh you get dyes too.. so you could have clear, blue, red, amber etc... You also get opage resin, but I can't see why you'd want to use that.
Ok got most of the parts, and a few weak substitutes, hope to have it all working in a day or so....
Would still be a little while before I do the casting though, as I need to get some better parts from overseas
HI Nordic
Careful with the resin. Around 1980 i sold a few MC step-ups based on LM394 (not that it matters). Due to extreme idiotism and paranoia i poured some epoxy on top and bottom of the PCB in an attempt to make reverse engineering impossible. Once the epoxy set and i powered it up i had a shock. The sound was practically unlistenable. Don't know if it was a change in dielectric absorption due to impurities in the epoxy but it certainly thought me a lesson. Those 394s were not cheap.
Even if DA is not an issue the dramatic change in structural rigidity and damping will have quite an effect on sound.
One thing a chipamp does not need is improving the heat dissipation.
analog_sa said:HI Nordic
Careful with the resin. Around 1980 i sold a few MC step-ups based on LM394 (not that it matters)....Once the epoxy set and i powered it up i had a shock. The sound was practically unlistenable.
So this was in 1980's? Do you think there has been an improvement in the resin to this date? I think that would be so cool to have your amp enclosed in a resin cube, or sphere even! Maybe it's worth trying. Even as a paper-weight it would look pretty cool!
Looks like alot of work, compared to just slowly filling a mold with a bit a resin for a base, let it dry, stick your things in, and top up with more resin, Spray can caps work well for making cylinders... in fact thats what we used in school... lol but that was 20 years ago...
P.S. I c't see any way of doing this without adding at least one LED
If you use anything other than casting resin, like quick set epoxy, you will probably end up with tons of air bubbles in the mix because most of them gas out while they set. Quick epoxy can also get VERY hot when it sets, and the more of it you use the more heat it will produce.
Yes, Casting Resin is what you are looking for. Here's a link for the type of material.
http://www.tapplastics.com/shop/product.php?pid=75&
Well consider that the very IC case is constructed of photocatalystic resin, I think the Resin housing would just become an extention of the IC in terms of heat distribution etc...
Also note that Heatsink side of chip will be exposed and connected to a heatsink... Been thinking of using a pc heatsink as that would allow the ability to add low RPM fans if needed.
if you have anything like a zobel on there which might have a resistor or other component that needs to dissipate heat, make sure to use a larger wattage than you would for free-air because the heat has nowhere to go except out the wires of the resistors, and its not like you can just de-solder them if it is wrong.
- Chip Amps
- Case idea to make you resin-ate
