Also: http://www.diyaudio.com/forums/multi-way/192737-2-way-waveguide-cardioid-like.html
What mid and or bandwidth are you looking to cover?
Its a work in progress but I am aiming for around 17-1800 to 5-300 hz. LP is governed by the dipole peak of the mid (SS 18wu) and HP will be decided based on SQ in the midrange. I do not want to use too much EQ on the midrange driver. Perhaps a nude driver with felt mats covering the rear out-put will give me peak at 17-1800, but a the same time gain more dB below 1000 Hz due to cardioide effect?
Joined 2009
- Cardioid midrange
