If you parallel two 4700 to make one 9400 uf, you should hear no difference.
I make cap assemblies out of smaller caps; two pieces of polycarbonate plastic with holes drilled, the caps, some 18 ga wire, and 2" #6 screws & nuts. I then screw the whole assembly to the main board to keep it from flopping when I carry it around. I had room in my case, you have to evaluate your own space requirement.
3 mm screws & nuts in your part of the world. Use elastic stop nuts so they don't come unscrewed.
