Capacitance Multiplier
Superficially, your result looks to be the same as (the positive half of) that taken from Rod Elliot's site, unless I have missed something here.
However, there is no need to have 2 separate connections between the + terminal of the bridge and the collectors of the 2 transistors, as you have shown. These 2 traces are simply in parallel with each other.
Regards,
