can someone tell me what size power supply i would need to run these from?
Product Number
AA-AB33182
Product Name
4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board
for subwoofers.
10-32v input
Product Number
AA-AB32181
Product Name
2*100 watt @ 4ohm TK2050 Class-D Audio Amplifier Board
speakers.
10-30v input
would this work well?
eBay - The UK's Online Marketplace
thanks for your help.
Product Number
AA-AB33182
Product Name
for subwoofers.
10-32v input
Product Number
AA-AB32181
Product Name
speakers.
10-30v input
Should work OK. But you won't be able to drive all those amps at full power with just one PSU; there's not enough current available. For normal use with music you shouldn't have a problem.
i was planning on running each module from its own power supply, i'm just completely confused as to what i'm looking for. i read a link on making your own specifically and it messed my head up for hours of reading the same article over and over again.
yes, that PSU will power the amplifiers.
You may need to add some filtering between PSU and amp PCB.
Are you aware that these are not 100W amplifiers?
Each amp is more like a 30W to 35W specification when run on 30Vdc.
On 24Vdc they will be considerably less.
care to expand? especially the filter part?
4 Channel 100W TK2050 D class Audio Amplifier Board Assembled | eBay
as far as i was aware these were internally bridged amp modules.
thanks for the replies.
100 watts @ 4 ohms means a voltage swing of 56.6 Vpp. Even in bridged mode you can't expect this voltage swing from only 24 Vdc, no matter if, or how you expand filtering. You will need a DC supply of at least 33-35 V for bridge mode, or 65-70 V for a single power output stage.
Best regards!
Best regards!
- Power Supplies
- can't get my head around PSU's, help choosing.
