No.So I need an mini to usb adapter?
You just have to use the adapter supplied with the S8 OTG adapters? - Pg. 2 | Samsung Galaxy S8
Do you have a powered USB hub?
What is that? How does it work.
If you don't know, it is probably best not to start now.What is that? How does it work
No insult intended. It is one of those situations where it would make sense if understood but probably difficult if you don't.Hi T. I've read your post many time and don't know if your are saying it really doesn't matter or if I'm that stupid, it's no use anyway.
As you can see from my signature, I'm comfortable with that part of technology, others may not be so.
