Cambridge Audio A3i repairs and mods
G33/33 said:
Hi Alex,
is there any alternatives for ZVP3306A ? I can't find it in Indonesia :bawling:
can I use IRF 9610 / 9510 ?
ZVP3306A is available from Farnell. Possible alternatives are ZVP3310A, ZVP2110, ZVP4105, BSP254.
IRF9610/9510 are far too big for this position and would seriously impair performance and stability. I am considering now an "upside down" version of the amp, using PNP input and N-ch MOSFET instead of P-ch - as there is wider choice of suitable devices. Another possible P-ch alternative could be 2SJ76-79, I may try it in that position and see what happens.
Alex
IRF9610/9510 are far too big for this position and would seriously impair performance and stabitity. I am considering now an "upside down" version of the amp, using PNP input and N-ch MOSFET instead of P-ch - as there is wider choice of suitable devices. Another possible P-ch alternative could be 2SJ76-79, I may try it in that position and see what happens.
Alex
Thanks Alex,
I will try to find BSP 254 and 2SJ76-79.
rgds,
G33/33
Hi Alex and All,
for the power bjts I would like to suggest the a1943 and c5200 by Semelab , I have tried they I can say the Semelab works very fine more than the same bjts by other companies.
I have used they in a my amp. I have found they at Farnell.
For q9 I would like to suggest the bc327.
for q8 and q10 other changes don't improve the sound for their configurations.
change q9 I think it's important.
for q3, q4, q5,q6 other changes don't improve the sound for their configurations.
Pier Paolo Abbate.
x-pro said:
I've designed that amp more than 12 years ago. As it happened, it was designed to be a 40W per channel amplifier but at the last moment it was promoted by the management into 60W just by boosting the supply voltage. That and also poor quality PCB and some components contributed to a common fault - as a result of a local board overheating one of the LED's (usually LED2) or Q8 transistor next to it (BC640) goes open circuit. Thankfully, protection circuit in this case just disables the output. It is useful, if you came across this amplifier, replace both LED2 and Q8, mounting them at least 10-12 mm from the PCB.
I think this is exactly the problem with my A3i, I've ordered new LED along with a BC640, hopefully I should have a working amp again. Thanks for posting this info and the schematic. :)
Another update.
After playing in LTSpice with A3i circuit I found an alternative way to compensate it, resulting in a substantial increase of OLG at high frequencies and better THD figures. Here are the results after I've tried the simulated network on a real A3i:
THD+N measured by Amber 3501 in 300 kHz measuring BW for full 50W into 8 Ohm are 0.006% for 10 kHz and for 0.008% for 20 kHz - . At lower frequencies or levels distortion are on the limit of my measuring equipment. Attached picture shows the spectrum of 10 kHz 10V RMS into 8 Ohm - in 48kHz bandwidth THD is 0.0004% .
Alex
Hello,
my A3i amp died two weeks ago and I found the fault Q8 transistor that I already replaced.
I thought it would be all fine, but after listening to some music for a few minutes, loud DC noise (again) in same channel speaker + relay protection (outputs cut).
Turning the amp off then on again, seems to work for a few minutes, no more.
The LED2 seems to be fine (lighted). Can it still be damaged? SHould I replace it anyway? It's almost sticked to the PCB, but not warm at all and visibly working.
When turning to faulty state, I can measure about -30 Volts on the collector of Q8 instead of 1.1 Volts (that I can measure on Q108, or when starting the amp, on Q8).
Any help greatly appreciated.
Gilles
r7aake said:
Hello,
Gilles
Hi Giles,
yes, it is most likely that LED2 is faulty. Just replace it and lift the replacement at least 10-12 mm from the PCB.
Cheers
Alex
Hi Alex,
I replaced the LED2 today. I simply cut the old one on the PCB and soldered the new one directly on the remaining "legs", therefore at least 20 mm above the PCB. Also the Q8 trans was installed this way. Not nice, but replaced within 2 x 2 minutes!
Unfortunately, today, after listening to some music for 10 minutes (very mild volume), the amp relay switched off again.
Some clues:
Even after the relay switches off, the LED2 is lighted, and I can measure about minus 30 Volts on the Q8 trans collector.
I presume that another active component got damaged due to the initial Q8 death (in bypass). Do you have any idea?
Again, Alex, thanks very much for all your help.
Gilles
r7aake said:
Hi Alex,
Hi Giles,
that is not a good way of replacing devices! It is just possible that there is a dry joint on the PCB that you would see it if you remove the PCB from the case. It is really quite easy - you need to remove 6 screws from the speaker connectors at the back, 4 screws which hold the PCB supports from the bottom and 4 more that hold the heatsink brackets from the top. Disconnect a short link on the input and the whole power amp assembly can be lifted out and turned upside down for a proper inspection/repair.
Cheers
Alex
ppa said:
Hi Alex,
I would ask you: why have you designed voltage references whith LEDs? Is there a particular reason for this?
Hi Pier,
LEDs just look nice :) . You can replace them with 3 diodes in series if you wish.
ppa said:
My compliments for the solution to eliminate the resistor into the mosfet's gate to avoid its oscillations.
Pier Paolo
Small MOSFETs are not as prone to self-oscillations as large MOSFETs. In this case there is no need for a resistor there.
Cheers
Alex
Hi Alex,
So far, it's all sorted out. I found out that after a few minutes of mid output power, the LED1 was shutting down.
I have unmounted the PCB as you advised, installed 4 bran new green LEDs, installed also correctly Q8.
For info, original LEDs in my amp were all yellow, not green.
Thanks again for all your help and for this nice amp design and sound.
Gilles
Good. That most likely should cure it.
Interesting - I never have seen one with yellow LEDs. It would not make much difference as a voltage drop on these should be similar to that for green LEDs.
Cheers
Alex
Power into 4 Ohms
Hey ho !
I have been using my repaired A3i now for a while, and it sounds realy great. (Thanks to x-pro for the fast help !)
Now I´m going to drive my main speakers with it, because I don´t have any other amp at the moment.
(Theese: http://www.visaton.com/en/bauvorschlaege/3_wege/concorde_mkiii/index.html )
How mutch power do you think can the amp provide into 4 Ohms and what is the weakest point then ? I don´t think it will be the output transistors if i provide a good cooling.
How mutch power is the transformer ratet ?
I also will replace the main caps to higher capacity ones.
Thanks in advance, have a nice weekend !
falk
Re: Power into 4 Ohms
at-2600 said:
Hey ho !
Now I�m going to drive my main speakers with it, because I don�t have any other amp at the moment.
How mutch power do you think can the amp provide into 4 Ohms and what is the weakest point then ? I don�t think it will be the output transistors if i provide a good cooling.
falk
Hi Falk,
A3i will give about 100W per channel into 4 Ohm and should be OK with these speakers if you will arrange a good cooling.
Cheers
Alex
