Hi, Are you using DSP for you active crossover?Nice baffle! Sorry, i have an active crossover and individual amps for each driver, which is very good to lift the low end to my likings.
This is a very interesting thread which has got me considering building something again.
I don't think I've seen it posted, but what size baffle are people using.
In addition is there a dipole tweeter the could be used as a replacement for the Dayton Audio RST28F-4 1-1/8"?
Anyone actually got around to build this speaker with the passive crossover that can share how it worked out?
I think this speaker would fit perfect when looking at the WAF factor - size, looks and price are perfect and could easily be pushed against the wall when not in use. This is something I need to take into consideration but would of course want as good sound as possible,, but will not chase down the last few percentages if size, looks and price nevertheless will excludes it from being accepted.
I hope someone can give their opinion about the speaker using the passive crossover - I would be really happy.
Thanks.
Thanks.
Building this speaker with the passive crossover and also possible to active minidsp crossover. Did nit like the crossover in the speaker itself so i printed an enclosure for it. And made an backplate for hiding the wiring. View attachment 1306640 View attachment 1306641 View attachment 1306644
I really really like your build. Please tell us how they sound.
Hello, i ordered the speakers and searching for the drawings of the baffle and crossovers. Who can help me?
- PRODUCT DIMENSIONS: 38”H X 18”W X 10”D (including support legs). 35 LBS EACH
First the angle, it is 45 degrees, the thickness of the baffle is 38 mm I made the 45 degree edge 28 mm deep but I think you better can stop at 25 mm, specially if you use MDF. Otherwise you you will have serious trouble with screwing the woofers to the baffle. You need to pre-drill the screws but not too big and not too small please test before drilling your baffle.
An alternative would be to use speaker cleats, which will move the screw holes into the baffle further away from the chamfer cuts.
I'm currently not building the Calandan, but doing a similar set of butcher block baffles with rear mounting drivers and front 45 degree chamfer cuts.
Using these (cut shorter) for the cleats:
https://www.amazon.com/dp/B08KW6MMHB?psc=1&ref=ppx_yo2ov_dt_b_product_details
- Caladan by Clayton Shaw DIY
