CAL PCM1702 dac board PMD100 CS8412..$75
Complete dac board from CAL CL-15 HDCD player
PCM1702 with Power Boss power supply(BIG)
Fully discrete output (i/v)
'Super cap" on dac power pins
PMD100 HDCD decoder
CS8412
Twin transformers
This board has a bad main processing ic , so the unit would no longer turn on.
I sold the disc drive ; only the board and chassis are left
Very well engineered circuit board. Bypassing the main ic or rerouting the power to the dac section will be required.
$75+ shipping. Chassis available for just additional shipping. .
Do you have schematic to connect CS8412 to PMD100?
I would like to connect SPDIF to CS8412 and then to PMD100 of my Old CD player Rotel RCD-971.
I only found CS8412 to DF1700.
I think DF1700 and PMD100 has adapter but I only found adapter of PMD100 to DF1700
Hence my CD player has PMD100 so I want to connect CS8412 to PMD100 directly.
Thank you very much
Thank you very much
