cadence FXA1200D strange problem...
Good evening friends...im working to this amplifier and i have the above problem...when i plug it with 13,8 volts it starts with 2 amps and immidiatelly getting down at 0.7 amps....after 15 seconds the draw is again 2 amps and the amp shut down...i have a similar amp and the 2 amps appears only when it beggins....then is working fine....i am confused with this...any help???
