Anybody have any experience modelling waveguides and getting them CNC milled into wood? I'm thinking multiple sheets of plywood stuck together for the depth.
I've seen the oblate spheroidal equation, how would one go about putting this through a CAD program? I've got sketchup....
How about a non-axisymmetric profile? Like the 18sound XT1086 but bigger to match bigger woofer...
Ta
Ta
Yes, I'm doing exactly that. I'm actually waiting to put my motorcycle engine back together before starting to cut a 320hz LeCleac'h horn. Sawdust in the crankcase = no good.
The details of drawing a curve like that in a Cad system vary with the system, but typically you'd draw enough points to describe the curve and then fit a spline through them. In my very limited experience with it, Sketchup is not what you want - it is for sketching, not for accurate technical models. That said, if it can export IGES or STL files, you might be able to make something useable with it but I would definitely check that first. Personally I use Pro/E or Autocad. Other packages to look at would be Solidworks, Unigraphics, Catia, etc. Solidworks is probably your best bet. The others are expensive. I haven't used the latest version of AutoCAD, but in the older ones (just a few years), you can't draw something like an elliptical horn as a solid model.
Another thing to watch out for is what CAM software your CNC shop has. If they don't have something moderately complex, they won't be able to cut out 3D shapes like this - well, they won't be able to import a 3D model and from that program the cutting paths for the shapes. A lot of shops with operators who are more experienced with the machining side and less with the computer and cad side don't have the necessary software in my experience, as this software is also not cheap.
Cool, I'll check out solidworks...
Is this true of all woods? How bad is it? What about when painted/sealed? (I obviously have no experience here ) I notice people building Gedde's kits painting the waveguides, but I'm not sure if that's all the way into the throat.
Are there any other materials suitable for this sort of thing? I'm only building 2... These aren't for prototypes, and they'll get used outdoors sometimes.
Does anyone have equations for an elliptical waveguide?
Thanks,
not smooth enough for the throat to perform as designed.
Thanks,
I have not had too much experience with varous wood, but. It seem that if wood has tought fibers, then it would be difficult to mill. The spinning direction and angle at which the cutter crosses the fibers causes various degrees of roughness. Other alternative might be arificial wood.
What about Geddes Data?
I think I saw a spreadsheet somewhere but I can not find it now.
btw, Im very interested in this stuff also.
The oblate spheriodal waveguide contour is public domain and is desribed in the thread mentioned above. But the elliptical version has never been defined - publicly. Here is a picture of the one that I had cut. Way too expensive to do as an actual device. The costs only make sense if you can mass produce them.
Does it perform as good as you expected?gedlee said:The oblate spheriodal waveguide contour is public domain and is desribed in the thread mentioned above. But the elliptical version has never been defined - publicly. Here is a picture of the one that I had cut. Way too expensive to do as an actual device. The costs only make sense if you can mass produce them.
Re: Waveguide milling
Uh, CNC doesn't come cheap!! Its several thousand to do what you see.
Sure its easy if you have the machine, the machine does the work! Are you saying thta you will do CNC work for me for free? I WOULD take you up on that!!
Any form of glass is time consuming and costly and ends up with only an average product. I wil never use glass again.
fb said:Thanks all....
I'm curious why the elliptical ones are so expensive to build? CNC mills can do complex arcs as well as circles can't they?
optichammer said:It's pretty easy to make a mold and lay these up in fiberglass or carbon fiber, etc. I can CNC this stuff out as well. Anyway... just let me know if I can help!
- Eric
In case you didn't notice, that just a part of a mold!! There are at least another several steps (and several months) before anything can be measured.
Several thousand seems like pennies if its for mass production? Or 1 hour on the craps table...take your pick
There has to be CNC shops out there hurting for business in this economy no?
Machine time, programing time, fixture and alignment, mostly you can see is manhours. For the simple one I did in the Geddes thread, it totalled around US$600 for one.fb said:Thanks all....
- CAD modelling of waveguides for CNC milling?
