AndrewT said:Hi,
can posts 83 to 179 be summarised into just two?
Why do we regularly hear that LM3886 have failed, gone awol, don't work?
Can't be anything to do with connecting the pins incorrectly then!
The chip has a lot of protection built-in but some combinations of shorting will, no doubt, blow it up. It's only a fiver for a new one though.
Instead of critiquing my posts can you explain to Mike what the circuitry does please? I'm sure you know.
Simon
measure what happens over a range of operational and temperature conditions, before connecting speakers and particularly expensive speakers.mikesnowdon said:Well I've looked at the circuit and its easy to disable it and diconnect it from the output. I'll give it a go and see what happens.
mikesnowdon said:Theres a connection from the microprocessor to the output relay. I think what its doing is detecting abnormal DC offset and triggering the output relay as some kind of speaker protection.
Anyone?
Bingo. I very much doubt that's causing your buzz though.
Dan
I've been studying the circuit with directly mounted decoupling caps in mind. Looking at where the ground traces go I noticed the decoupling caps ground to the 0v (nice thick trace) on the 17v trafo secondary, and eventually the star point on the main smoothing cap. The GND pin (pin 7) of the LM3886 connects to the star point on the main smoothing cap - which connects to the 0v on the 23v winding. The Ground trace from pin 7 on the power chip seems to go via all the main areas of the circuit - Opamps and input selector, phono sockets, etc.
Is this done to get improved decoupling on the power chips?
My consideration is that if I hardwire the decoupling caps then I have a longer path to ground which has a lot of vias along the way.
What would be the best way to hardwire my 100uF 50v BG STD's in the above circuit?
Mike.
Hi Mike,
Sorry I haven't been able to respond earlier.
Hope that helps, Chris
This is normal for most audio equipment. Historically too. You can reduce the range by turning the gain stage into a nice buffer. I'm not sure if the gain reduction affects the actual PSRR, but it won't be amplified as much. I guess that's what Greg is getting at. A better buffer and supply regulation / filtering will be of more use to get rid of supply noise.As it is this is too high for me - the amp goes into clipping at the 12'oclock position - wasting useable range in the pot.
Yes. This circuit will detect a DC voltage on your output lines. At some voltage, it will act by shutting down the output. This circuit will not affect your amp in normal operation. Therefore, leave it in. It's never a good idea to bypass protection circuits. Even an internally protected chip amp can fail DC. That wasn't very hard to explain.Can anyone advise on the DC offset detect please?
Yes.Theres a connection from the microprocessor to the output relay. I think what its doing is detecting abnormal DC offset and triggering the output relay as some kind of speaker protection.
You may make things worse, depending on how well that transformer is shielded and how you dress the AC leads to it. To be honest with you, all you really need is good regulation and filtering between the digital and analog supplies. Again, try to look at all the options and the effects of each. Another transformer sounds impressive and may give you the idea that the supplies are totally isolated, but that is not necessarily true.Apparently digital electronics can put alot of **** onto the power rails which we dont want on our delicate output stages do we?
Decoupling capacitors are mounted near the "load". Any trace length or vias in between the load and power supply are the reason you are using decoupling caps. Some smaller capacitors will be found (or should be) near the rectifiers to reduce the amount of higher frequency noise before it gets into other circuits. Always deal with noise at the source. So, smaller capacitors can be decoupling capacitors or high frequency filter capacitors, depending on where they are located physically.My consideration is that if I hardwire the decoupling caps then I have a longer path to ground which has a lot of vias along the way.
Thanks Chris.
I dont fancy redesigning the input buffer so I'll give Gregs idea a try. Besides, with a LM4562 the amp sounds much better than with the NE5532. And later I'll be adding low noise discrete regs.
With seperating the microprcespor supply how about fedding the new trafo via one of those Shaffener filters? Im also considering adding a dedicated trafo for the preamp which might also benefit from one of those filters. I would shield any AC supply lines also.
What do you think?
What do you think?
mikesnowdon said:how about fedding the new trafo via one of those Shaffener filters?
Schaffner filters, like any filter, have to be matched to the load. If they are not, which is very likely, they may indeed worsen the performance of the amp. They will certainly not help against hum, because they are basically low-pass filters.SimontY said:Those filters sound cr@p, don't bother.
Yes, shielding may be a waste of time, because shielding efficiency decreases with the frequency.SimontY said:Shielding also seems a waste of time. Spend it on good passive components and keep at the shortening and simplification of the signal path.
How would good passive components help against hum?
Oh are we talking about hum? lol. Sorry, I was just in sound quality mode. Why is there hummm on a commercial amp? That's very odd. Do you have a ground loop Mike?
Have you tried unplugging all inputs and listening? Have you tried only connecting CDP? I presume you haven't connected the CDP to safety earth. You should also check the routing of any interconnect leads, make sure they're not going too close to AC power leads. You could also short unused preamp inputs, thought I doubt this will help much.
When did the hum start? Was it after an upgrade/mod?
Simon
Simon
Hi all. I'm planing to move into your discussion and make some little tweaks to my 340
1. Swap Opamp to LM4562. It has normal price (about 5$) and doesn't need any adapters. Maybe some time later, i'll offer some BD Adapters and put AD8066 There.
2. Change input Cap to lower value polypropilene (about 1uF).
[optional]: change all decoupling caps to polyp. (not so pricey as Mike's Mundorf,but something cheap like Epcos or our russian k73-17)
3. [Optional]: Adjust tone_Control section. Maybe change bass frequency and bandwidth. This part is optional, because i don't use tone all the time, but sometimes I want to set bass pot to about 3 o'clock... I think it's my speakers fault , but as soon as have them, tone controls section is usefull for me.
So who has any ideas how to count bass freq ?
4. Change Main PS Caps to Mike's Stock Caps (2*6800uf => 2*10000uf)
[optional] change diodes.
5. [optional]. Insert small +5V powersupply for source_selector section. Do You think that separate small trafo (5VDC 1A) + 78T05 VR + Rubicon MBZ litycs and some small-size polyprop... will slightly improve sound?
P.s. sory for my "broken" English
Simonty, see this thread:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=130909&pagenumber=1
here you can see a lot of internal photos:
http://s3am.livejournal.com/2319.html
- Chip Amps
- CA 340A SE LM3886 based amp - Upgrade advice please.
