Nothing better then snake oil that works!
It does work, but can easily be overdone. It works well on some cones (FR125 & Visaton B200 for example). The way it goes on is silky and kind of erie. It doesn’t work so well on some others. But what it does, at least in light of what i was doing, it doesn’t do any better than Puzzlekoat/ModPodge. C37 does smell better the tiny little bottle is way easier to carry than the case of ModPodge you would get for the same price.
I was gifted a half-bottle from someone who had it left over and i used it all.
Note: dammar is a much more affordable varnish you can play with... back in the days of the original FR Forum a numb r of members found out what overdoing the varnish does to a driver.
dave
ok, so the smallest bottle of 50ml would make dozens of drivers?
https://www.c37.net/
do you know anything about the different temperature?
can i take any temperature? https://www.c37.net/
if you see at the shop listing, it ask me to select temperature from 22c to 45c. i also have no idea what it meansI have no idea what that even means.
dave
Joined 2009
- C37 ingredient guessing
