I have just been re-reading the BA2 instructions and I see the 10uF supply line caps are in fact film caps not electrolytics. I've just been looking at the price of polypropylene caps and they are (or can be) very expensive but even more astonishing is their size for this capacitance. Am I reading this correctly?
Regards,
Chris
Regards,
Chris
Epcos B32926C3106M runs around $10 each at DK.I have just been re-reading the BA2 instructions and I see the 10uF supply line caps are in fact film caps not electrolytics. I've just been looking at the price of polypropylene caps and they are (or can be) very expensive but even more astonishing is their size for this capacitance. Am I reading this correctly?
Regards,
Chris
You can use polyester, polycarbonate to no ill effect.
I encourage you to take Elna Silmic! I changed very often the caps .. and returned to Elna!
put the negative side to the outputstage ...
Hi, just to clarify, it's ok to use the Elna Silmic both in the power supply and at the frontend "D" port?
As far as I know...... the Silmic and Silmic 2 series is only for audio purposes, there are of course Elna power capacitors, but they are not named Silmic and they have the high values (15000uF) you need....
good success
btw: even Nelson uses in Xp10 and Xp20 Silmics-
.... just because he bought drekload of them , not because they're good ....
( disclaimer for greenhorns - just joking , of course )
(disclaimer for greenhorns: Zen Mod is a talented young man - despite his ugly Engrish)
disclaimer for greenhorns - generg is not objective , regarding ZM
Hi ZenMod,
Why is Aleph3 capable to deliver 50 W in 4 Ohm as a single ended device and Push Pull BA-2 is doing just the same?
Is it the dynamic aleph current source?
yup ;
(generg old, ungifted and white)?
(ZM old, ungifted and black)
it seems we like same muzak
YouTube - Young, Gifted, and Black(Live)- Donny Hathaway
I think BA-2 depends on your Heat Sink capabilities and your willingness to run high bias and/or higher voltage rails. The article seemed to be written that way and the DiyAudio boards designed with 3 pairs or 6 pairs but, some of the chasis with 4 or 6 pairs? Kinda more build to taste
And then, there is class AB operation...
Thanks for the info you guys (and gals?).
I had bought some Rubycon RX30 caps at 10uF before re-reading the article but I haven’t listened to them so I was betting on the label. I recently tried some 220uF caps with a 12V power supply. The layout was a diode bridge, 22000uF cap (Mundorf Mlytic), voltage reg (LM338), 22000 cap (Panasonic) and then the 220uF cap. I compared a Rubycon ZA and an Elna Silmic of the same value. The silmic came across as very easy on the ear (the power supply was running a Pure digital radio which I did my listening tests on), very analogue but in comparison with the ZA it was a little too warm in the bass. The ZA was very relaxed but more transparent and produced a tighter bass. Who would think a single component could make such a difference considering there is another voltage reg in the radio. So for this reason I probably wouldn’t go for the Silmic (although I’m using them to good affect in a Quad FM4 tuner on the power supply). I would have gone for the ZA caps but they are not made any more and I couldn’t find the values I was after.
I bought some 10uF Ampohm Polypropylenes last night for about £8 a throw as they appear to be made in the UK, are audio grade and Humble Homemade HiFi guy likes them.
Congratulation, good decision and founded on your own.....
Yes the silmics emphasize a bit the upper bass region! I like it. I heard silmics against Obbligato and the decision was not easy, the Obbs have better colors, but bit less dynamics ....
The good with DIY you can decide now and change later again.......
it seems we like same muzak ....
Hi Zen Mod this was more my version...
YouTube - nina simone - young gifted & black
how the time changes....
I dunno, he looks pretty old in his photos.
- Burning Amplifier BA-2
