Building a symmetrical PSU B1 buffer
Hi
I've finished stuffing the board and everything appears to be OK.
I am getting +10.17v and -9.52v at the shunt output, and the DC offset is R=0.1mV and L=0.2mV when idling. It does occasionally rise a bit when turning on or off, but I understand this is to be expected. The relay also clicks-in after a few seconds. I will be using this with my F5 so I'll be adding a 1uf cap on the amps input.
Is there anything else I should check before connecting my LDR attenuator?
check the voltage drops across the CCS resistors.
check the output offset from OFF to ON and from cold to operating temp.
The relay should be open when the circuit starts up and open again when the circuit shuts down. You should not see a DC pulse at startup nor at switch off.
1uF for a DC blocking cap seems quite low in value for the input of a Power Amp.
Are you intending to EQ the bass for a particular sound effect?
Hi
I thought 1uf was the correct value for an F5. I'm sure I have seen it mentioned elsewhere. But if I'm wrong...
http://www.diyaudio.com/forums/pass-labs/145201-building-symmetrical-psu-b1-buffer-90.html#post2059999
All of the LEDs measured 1.8v when testing prior to soldering, the relay clicks after 5 seconds after turn on, and clicks again straight after switch off.
I measured the voltage across the 2x68R (34R) resistors. Negative side 1.76v and positive side 1.64v
I've just rechecked the dc offset whilst 'cold' and there doesn't appear to be any, just a slight bit of interference from the DMM. I will check the 'hot' readings a little later. :)
diyAudio Chief Moderator
Joined 2002
Looks like working perfectly OK Richard. Congratulations. In the graph is the high pass you can expect when coupling 1uF to 100K load.
Thanks Salas. That graph looks good?
Have a proper look.
That graph of low frequency response is for 1uF & 100k.
The output of your circuit is already loaded with 100k.
To achieve that graphed response the following Power Amp or receiver needs to have Zin = infinity.
If the actual Zin = 100k, then the resultant load for the HP filter is 50k. This moves the graph one octave to the right.
The F5 has no DC blocking cap at it's input so the 1uF works alone.
The Zin ~ 101k.
This leaves the HP filter F-1dB ~3Hz.
This is OK for many.
If as stated earlier, a Zin=20k were used then F-1dB moves to ~17Hz.
If that Zin=20k power amp had a capacitor of 4u7F as a DC blocker then F-1dB moves to ~22Hz
Summarising:
1uF at the source output only suits very high Zin at the receiver that is DC coupled.
then try mix and match if you believe this is an issue.
I believe it is far more important that the input filtering is of narrower bandwidth than the amplifier/pre-amplifier can reproduce well.
eg. setting the amplifier input filtering to F-3dB @ 3Hz and 200kHz, requires the amplifier to work well over the bandwidth of 1.5Hz to 400kHz.
Hi
I have just finished wiring my L/S attenuator into the DCB1 and I appear to have some DC on right output channel, left appears fine.
When I turn on the attenuator and DCB1 at the same time the right channel peaks at ~1.4v before the relay clicks in, and then drops to 0v after the 5 second click. When I turn it off the right output peaks at ~800mV and very slowly decreases. As I am only in the checking phase I haven't connected it to my amp...thankfully :p
Any ideas?
