If you use a switching supply then the 2N3055 will not be any good as they are nowhere near fast enough.
If you use a sinewave you need something other than 555 timer and the thing will be huge and hot.
I think you will run into a lot of problems unless you are a bit more experienced, best to just buy an inverter in this case.
